Originally Posted by
Skitch
what framerate are you trying to achieve??
Long story short, best result in AE are even doubles of your source footage, so if you want final to appear like 96 fps, shooting source at 48fps will give best results... if 120 fps is final desired, shooting source at 60fps would give best results... etc....
That being said, AE has a filter/time effect called "timewarp" which works very well, and essentially creates "tween" frames between your source images. To use it, simply import your footage at 24 fps (assuming of course your final output will in fact BE 24fps...), and apply the effects/timewarp effect...
the default settings automatically double the theoretic fps (the default setting plays your footage at 50%) but this is completely adjustable. And you can do any percentage, faster or slower, and get some astounding results... even doing animated ramps, etc.
On your first time through, just make sure you have these two initial settings picked:
choose the "method" as "pixel motion", and the "Adjust Time By" to "Speed"
After that, adjust your speed setting, and have fun!
(Be forewarned that this filter can require a lot of tweaking, and depending on the source footage, you may seem some bizarre artefacts, after inital processing, such as image ripping, tearing, blurring... but once you get familiar with the effect, you can minimize and often completely remove many of these... )
Also, please note that this effect is a processor and RAM hog, so expect longer than usual render times...
Hope this helps!
-SK
