Click here to go to the first RED TEAM post in this thread.   Thread: Overview Diagram
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
  1. #11
    Jan 2007
    Detroit, Mi
    Very self explanatory! Great Work!
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    "FUBARed"
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    1270p is listed as s35mm, not s16mm. Upper-left quadrant of the chart, following the 10gigE output from the RED ONE.
    Moderator Tom Lowe's Avatar
    Jan 2007
    what is the bottleneck or speed limitation of the SATA connection going out to the RED Flash? If you threw 20 large CF cards into a RAID configuration, could that connection handle 900MB/s, for example, to record high-fps 4K uncompressed to flash memory?
    SATA (presumably SATA II here) tops out at 300MB/s.
    - Jeff Kilgroe
    Jan 2007
    Quote Originally Posted by AppliedVisual View Post
    So is it unknown how we would record the uncompressed raw files?
    Paul Wizikowski
    Cloud 9 Productions
    Senior Member david farland's Avatar
    Sydney
    They've said it's to be 10gig Ethernet fibre.
    I'd presume as they're released the raw port price ($6,500) they'll give details of this interface at NAB.
    Also expecting details of REDRAID sometime!
    REDRAID is RED product that records uncompressed off Raw port.
    DF
    Junior Member
    What distance is allowed to have between Red-Drive or Red-Ram and Camera. Is there a maximum distance defined by the eSATA connection?
  10. #20 update considering FCP6 featureset?
    Junior Member
    Feb 2007
    hi Michael,
    thanks for the great diagram. i suppose that the imminent release of FCP6/FCS2 would imply some additions/changes to your diagram... specifically in the area of FCP6's ability to drop/work with REDCODE RAW files directly in the timeline -- which presumably (unless i have my information wrong) means that you can skip the initial REDCINE step?
    thanks again for doing the work to put that diagram together.
    -t
