Thread: recording reference sound for music video?
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 recording reference sound for music video?
    SO the only aspect i'm not understanding yet is how to record reference sound for a music video -- as i don't see any XLR inputs. ANy insight into it?
    There are Mini-XLR connectors. I believe the camera is provided with adapter cables.
    Dylan Reeve
    Edit Geek
    Senior Member NateWeaver's Avatar
    Aug 2007
    On build 15, I plugged a cheap Sony PD-150 mic in via the adapter, taped it to a top rod, turned on phantom, and away we went.
    Worked perfectly despite the fact I didn't have time to test it.
    Nate Weaver
    Director/D.P., Los Angeles
    www.nateweaver.net
    Junior Member
    Feb 2008
    Sycophant is correct...
    There are four mini XLR connectors, but I don't know if RED is including the adapters for free.
    RED gives you one adapter with the camera, at least I'm assuming they do. Additional ones are $50 each. There are 4 mini-XLR ports on the camera. I don't know if there is anything special about the RED XLR adapters or if others will work, haven't tried... I also assume it's just a standard mini to full size XLR adapter.
    - Jeff Kilgroe
    Senior Member Adrian Van Rossum's Avatar
    Aug 2007
    Queensland, Australia
    It appears the RED audio cables are not bog-standard off-the-shelf, but are specially wired for use on the RED. There's an entire thread about it at
    http://www.reduser.net/forum/showthread.php?t=9991
    Adrian Van Rossum
    "Blokes" Pixel Pusher
    www.blokes.net.au
    NateWeaver, i liked your answer cause that is the solution i need -- cheap mic somehow attached to the body.
    Be warned - Phantom Power from the camera should not be used with the current build (15) as it introduces static.
    Dylan Reeve
    Edit Geek
    Aug 2007
    Quote Originally Posted by Sycophant View Post
    True I'm sure, although I didn't notice it in my particular situation, and even if there had been noise, it would have been ok for the purposes of this thread.
    Nate Weaver
    www.nateweaver.net
    We've taped on shotguns and lavs, but the cleanest scratch track would come from a feed from your audio playback guys system, be it a DAT or straight out of your playback source (CD player, boombox, etc).
    I'd tell you that an editor we know used the scratch track for his entire offline, and we laid back the actual DAT track in online, and didn't notice a huge difference, but you might not believe me.
    If you are using DAT, remember when shooting 23.98, pull the audio package at 29.97-
    971 & 972
