Click here to go to the first RED TEAM post in this thread.   Thread: Redcine-X Pro Not Exporting
Results 1 to 9 of 9
  1. #1 Redcine-X Pro Not Exporting
    Junior Member
    Feb 2014
    Every time I try to export my 4K footage it says "Running" in the Export window, the ETA clock starts going up and up, the Progress meter stays at 0%, and then...
    RedImageExporterToExternal::cancel unable to send abort message to client.
    RedImageExporterToExternal::cancel failed to receive stop message from client.
    RedImageExporterToExternal::cancel unable to stop export client.
    I have tried to follow every tutorial online, but the same result. Is there a setting I'm missing?
  2.   This is the last RED TEAM post in this thread.   #2
    Red Team
    Sep 2009
    Irvine, CA
    Hi Paul,
    Please do a "Save Report" from the help menu and email that to me at redcinex at red dot com.
    Thanks,
    David
    Mar 2008
    Dubai UAE
    Hi, Has there been any update on your problem, I am getting a similar issue.
    Ian
  4. #4 mine is exporting ... now
    Hi there,
    i had the same problem.
    in my Quicktime preset i changed the "Output location" to "custom output"
    it did not work with "Ask for Output Filename".
    Michael
    Senior Member Marc Berger's Avatar
    Dec 2007
    France
    Any new insights for this problem?
    How many sources would you transcode in one time?
    I reached this problem when try to encode over 1000 files in one time. But if I convert 500+500 files, error gone.
    In my case, error appear anywhere between 628-748 footages.
    And you must restart Redcine-X each time after this error appear.
    Sorry to resurrect this old thread...I just can't get Redcine-X to export any of my files either. Stuck at 0%
    I have the same problem but with just one batch of clips.....stuck at 0% but plays fine in RCX. Crashes RCX everytime I try to export any clip from this one SSD. Is it possible to lock the clips somehow so they can't be exported?
    Senior Member Justin Batchelor's Avatar
    Nov 2010
    London, U.K.
    Same problem here. Crashing when trying to export
    And the imports to Premiere take forever as well.
    Not sure what I am missing. Sending report
