Thread: PowerMAC and 4K
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 PowerMAC and 4K
    Senior Member Ameer Azari's Avatar
    Feb 2008
    Hi,
    I've been hearing that one can get a PowerMac G5 for under a thousand dollars, and then add RAM, Memory, Graphics card etc. 30" Dell Screen
    and all that will lead to an easy 4K workflow,
    I don't know much about the PowerMac's so I had a few questions:
    1. What's the maximum RAM a PowerMac G5 can take
    2. Will the Dual processor's be enough or will it buckle under 2K in FCP
    3. Will it accept the 8800 GT Nvidia graphics card
    4. Will it work with the Kona 3 Card
    If it can take 16GB RAM, a 8800 GT then you're looking at a system that costs ~$3000 that you can edit 4K with! YIPPEE!!
    Jan 2007
    Melbourne, Australia
    REDCINE and REDAlert, the two primary R3D tools do not run on 'G5' class Macs, you will need an Intel-based Mac Pro.
    Cail Young
    Problem Solver
    Inspiration Studios, Melbourne, Australia
    Feb 2008
    Cincinnati, OH
    How about, instead of buying an old machine.... you buy an iMac. Now, I understand that an iMac is not the "serious" machine. But judging from your post, you're not serious. Get a 24" iMac, throw 4 gigs of Crucial or Kingston ram in it. Add a G-Tech RAID for your scratch disk and if you think you'll be using the Prores workflow add an Aja IO HD. I have a Intel based iMac along side my Powermac G5 and there is a noticeable difference in performance favoring the iMac. Of course with all that being said, I plan on buying a Mac Pro to replace the G5.
    I've been running RedCine on the iMac to familiarize my self with the workflow and haven't run into an hic-ups. Understand that it will be slower then a Mac Pro though.
    Quote Originally Posted by Chris Hagan View Post
    How much slower??
    Banned
    Mar 2007
    If you want to work with redcode, an IBM PC-compatible system, no matter if OSX or Windows runs on it, is the way to go.
    If you want to use OSX, you should avoid the discontinued power pc architecture - many applications only run on intel/amd.
    if you are on a budget, the best way certanly is to build (or let built) and osx computer yourself. Intel 6600 Quadcore, GF8800, 8 GB, case and motherboard should be at ~1000 and this system will offer more than twice the power of a comparable imac.
    have a look at
    http://wiki.osx86project.org/wiki/index.php/Main_Page
    Quote Originally Posted by Red Guy View Post
    How much slower??
    iMac = Dual Core
    Mac Pro = Octocore
    A lot faster!
    8 times faster?
    Not counting a much much better graphics card, ram, bus, etc, etc.
    Stuart Ferreyra
    Timecode Multimedia
    Ph: 310.826.9199
    www.timecodemultimedia.com
    Creative COW - Apple Color - Instructor & Forum Leader
    Creative COW - RED Camera - Red Post Forum Leader
    Apr 2008
    You can't really do that on an iMac - the IO HD and G-Tech RAID will both have to share the firewire bus, and it just won't work (to the best of my knowledge, although I haven't yet tested it with my iMac or the IO-HD I have knocking around somewhere).
    If you want to do this, get a MacBookPro, which has an expresscard slot to run the RAID off. Just as powerful as an iMac in most cases too. I have the iMac extreme and a 2.33Ghz MBP, and there's not much performance difference, none to write home about anyway. Both are slugs compared to my 8-core Mac Pro anyway.
    Don't plan to work on 4K footage from a $20,000 camera and skimp on the post - it makes no business sense at all. Your time is (or should be) more valuable than any computer these days.
    Ben
    Ben Holmes
    Edit Out Ltd
    FCP/EVS Editing
    Systems consultant
    www.editout.co.uk
    Feb 2008
    Cincinnati, OH
    Quote Originally Posted by beneditor View Post
    Ben
    I wouldn't say you can't, The G-Raid does have a USB port on it... But I agree you're sacrificing a lot with this solution. I am merely posing alternatives. Alternatives that the budget minded crowd interested in Scarlet may appreciate.
    Apr 2008
    You can't use USB for ProRes capture or playback - it sends data in bursts, unlike firewire, which is what makes it so unsuitable for video. DV maybe, ProRes no.
    A quick check of the IO-HD manual will show you that the iMac is not supported by the IO-HD for this very reason - the only system configs they allow are via a MBP or a Mac Pro.
    I was a bit vague before, so I'll be a little clearer: You cannot use an IO-HD with an iMac reliably - if at all. I would not want any readers of this forum making any purchase choices based on the belief this was possible, because it just isn't. Trying to play back ProRes HD off an internal drive or an external USB drive will not work reliably, if at all.
    Hope that clears things up.
    Ben
    Ben Holmes
    Edit Out Ltd
    FCP/EVS Editing
    Systems consultant
    www.editout.co.uk
    Feb 2008
    Surely you can work with 1080p on an iMac
    if you say no, I'm gonna cry...
