Thread: Dragon VS MX at MAX ISO
Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 61
  1. #1 Dragon VS MX at MAX ISO
    Senior Member Jean Guerra's Avatar
    Feb 2007
    Dominican Republic, Santo Domingo
    here is both my dragon and my MX at full ISO, i now we never use the ISO at its max point, but in dragon i begin to see the pinkish pixelation at 4000 iso, thats not good
    DRAGON IS THE PINK ONE
    MX IS THE GRAY ONE
    any advise
    Sep 2011
    Germany
    Did you do a black shading calibration on your DRAGON and waited for the camera to heat up to its operating temperature? I only experienced a pink screen at high ISO once and that was prior to calibration.
    Tobias Linden
    Director / DP
    EPIC-W HELIUM 8K
    #0748
    @tobylinden | tobylinden.com | hello@tobylinden.com | vimeo.com/tobiaslinden
    Feb 2007
    yes i did,,, I've done everything...on both my dragons i get the same thing...one worst than the other
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Marin County, CA
    FWIW, you have the temps set very low on both cameras. A sensor temp of 65 to 70 would be more normal.
    Sep 2011
    Germany
    Do you encounter vertical magenta stripes at lower ISO? If so, it might be possible that something is wrong with you camera. However, I think it's quite unlikely that both DRAGONs are affected by this error.
    Tobias Linden
    Director / DP
    EPIC-W HELIUM 8K
    #0748
    Feb 2007
    no ,i start to see them at 4000 ISO... but i can't have my cameras with this issue...i am a rental guy
    and yes both dragons have it... this is the one with the least of it
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Jean,
    I do not see a dragon 65 !! You need to warm up to at least 65 in Dragon adptive mode. Then wait 30 minutes and do a blackshading. Do this when the camera is hot.
    I do not understand your concern in these high iso!
    It would be more practical that you do a comparison with 2 images Mx vs Dragon same lens and same settings.
    So we can see if there is a problem.
    just a thought
    Grading Suite Davinci Resolve, Rental RED Digital camera.
    MONSTRO 8k CF #831 "BLACK PEARL"
    SCARLET-W #45 "HEIDI " , EPIC-W GEMINI # "DAFNE".
    ARRI ALEXA EV , ALEXA MINI LF
    SITE
    www.cine5k.ch
    www.rsi.ch
    Feb 2007
    yesterday i did that i waited for about 1 hour with camera on.. and then i did Black shading...today i powered up.. waited for about 1 hour ...and i still get this pink al over... i believe this could be hardware...
    Oct 2009
    Switzerland- LUGANO
    You can post a picture and a still r3d with temperature at 65 (whit blackshading at 65) and not 53?
    SITE
    www.cine5k.ch
    www.rsi.ch
    Moderator David Battistella's Avatar
    Florence, Italy
    What does your test prove or have to do with any image making. I'm sorry, I do not understand your logic. You might as well throw a capped alexa, nikon d800, canon 5d or whatever other camera.
    I mean, not even an r3d or a shot of a chart or something?
    Iso so has no effect on black shading calibration.
    Battistella
    "Colors are the wounds of light."
    -William Blake
