Thread: Smoking Kills
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1 Smoking Kills
    Senior Member Dominik Muench's Avatar
    May 2008
    Gold Coast - Australia
    A series of stills I pulled from my Dragon fashion film shoot with Danni yesterday, shot on canon 24-70 F2.8 at 250ISO, 8fps, 2:1:
    Dr. Dominik Münch D.O.C.A
    Filmmaker & Cinematographer
    Epic-W "Lucy"
    http://www.blacksun-productions.com
    http://www.instagram.com/drdominikmuench
    Nice. I really like the composition of these shots. Well done.
    -Mike
    Epic-X #3729
    Scarlet-X #1452
    Life is good.
    May 2008
    thank you michael, appreciate it.
    Epic-W "Lucy"
    Man 2:1 is amazing! Good stuff bro
    May 2008
    thanks dude. you should see the full res shots.....as I keep saying...If I could sync my flash heads with the Epic....id kick my DSLR goodbye.
    Epic-W "Lucy"
    Senior Member Ulf Krentz's Avatar
    Jan 2012
    Germany
    Quote Originally Posted by Dominik Muench View Post
    Nice work Dominik,
    I know what you mean, we just start doing stills with RED now, isn´t that true amazing, I really think we´ve got the best from both worlds (analog and digital)! Besides from the nice composition these shots really show the benefits we have with the dragon sensor. Just curious, what are your problems to sync your strobes?
    Cheers
    Ulf
    May 2008
    hey Uli
    thank you :)
    my understanding was that it cant be done ? at least not in the conventional way as with a DSLR ? I own a hensel porty lighting kit and I assume there is no way I can connect it to my epic and trigger it even though the handle has a sync port ?
    Epic-W "Lucy"
    Senior Member David Kuhn's Avatar
    Apr 2013
    Corning NY
    So I like the obvious double entendre inherent in the title... but the engineer in me wonders if you purposely chose a diesel facility because you knew that liquid diesel fuel wasn't really dangerous around smokers but that most viewers wouldn't get it... (triple entendre?)... because that would be epic (pun intended) and you'd get some serious nerd points if you did!
    David Kuhn
    Epic-M Dragon Monochrome #1995 (Dilbert)
    Jan 2012
    Germany
    Hi Dominik,
    You can trigger your flash via the sync port by assigning and pressing a button while you´re rolling. I suggest to use a remote trigger to keep your camera safe.
    I´ve done some work with strobes here: https://vimeo.com/106123939
    Cheers
    Ulf
    May 2008
    hey David
    unfortunately i didn't think that far ahead, my knowledge of combustible liquids is quite limited lol
    we saw the tanks standing there and just went for the shots sorry :/
    can you elaborate on this a little Ulf ? so I can assign a custom button on the handle that triggers my flash while Im shooting at lets say 8fps to keep the compression low ? that would be amazing. that video example looks great !
    Epic-W "Lucy"
