Click here to go to the first RED TEAM post in this thread.   Thread: Posterizing
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Posterizing
    Senior Member Steve Sherrick's Avatar
    Boston
    I noticed that I had a lot of posterizing today while shooting, and it was noticeable on both RED LCD and playback on an HD TV from the HDMI output. I'll be able to troubleshoot tomorrow when I get it into REDCINE, but is it possible that I had something set wrong? This wasn't a false color type of posterizing. Everything looks normal for the most part but things that are out of focus seemed to have this issue even more. For example, if I had a white pole, rather than a nice solid white pole, it looks like someone applied the posterize effect to it. My thought are:
    1. Maybe this is a dithering issue going from 4K to 720.
    2. Certain things are triggering it, as in certain lighting situations
    3. Could it be that I have something set in my settings that could be causing this to appear on preview?
    Once I get it into REDCINE I can see if it is still there. If it is, and it's in the footage, then I'm really lost as to what is causing this. I haven't noticed it before. The only two variable I have changed is I updated to Build 15 release version and I added the Nikon Mount with a set of Nikon primes.
    Thoughts anyone?
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    did you do the black shading after the update?
    if yes .. was lens cap on the whole time etc
    Aren't the video taps 8 bit? That would be a cause for posterization of smooth gradient material.
    Boston
    I did do a black shading and I always do it with aperture closed down, lens cap on, black wrap over lens, in a dark room because I'm paranoid about this.
    Maybe it is the 8bit tap. But I'm noticing this in my Nikon test I posted in the footage section. I had edited that from 2K proxies and rendered in a Pro Res HQ with Hi-Res selected in settings. Hmm.....
    I'll have to investigate tomorrow.
    Steve Sherrick
    Chief Collaborator
    STEVESHERRICK.COM
    Junior Member
    May 2008
    This posterization is always present on the LCD monitor. It is simply more noticeable in certain conditions. I assume it was present in the 'director's monitor' because of the HDMI output. I've always used and SDI output and never had this happen.
    Boston
    Yeah, it's just the truncation from 12 to 8 bits. The LCD shows this truncation pretty severely at times. But it doesn't affect things once you know why it's happening and that the RAW footage doesn't have it.
    Steve Sherrick
    Chief Collaborator
    STEVESHERRICK.COM
  7.   Click here to go to the next RED TEAM post in this thread.
  #7 Posterization
    Red Team Stuart English's Avatar
    Irvine, Ca
    The Preview HD-SDI and HDMI outputs are both 4:2:2 at 10 bits. So you shouldn't see anything like that there..
    Workflow Wizard
    Quote Originally Posted by Stuart English View Post
    Can I safely deduce that if I see the posterizing effect on the LCD monitor I will not see it in the RAW footage?
  9.   Click here to go to the next RED TEAM post in this thread.
  #9
    I've never seen posterization in the RED raw footage - ever.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Quote Originally Posted by Graeme Nattress View Post
    Graeme
    So if I may ask, what is causing the posterization in the LCD monitor? I'm still on build 15.
