Click here to go to the first RED TEAM post in this thread.   Thread: Should I try to use Time Code. . . or just forget it?
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1 Should I try to use Time Code. . . or just forget it?
    Hi all. . .
    I'm facing a quandry. We'll be shooting a feature film with the RED and recording our audio on a double system using the new Sound Devices 788T (8 tracks of audio).
    The question I have is whether the time code nonsynchronicities consistently discussed here mean that I shouldn't bother trying to use time code in the production at all, and just rely upon the old mechanical clapper system for synching sound.
    What advantage do we have using the time code (we'll be using FCP 6)?
    If there IS an adavantage to using time code, should be try to synch everything with a Denecke time code slate or just synch off the camera or synch off of the 788T?
    Thanks very much.
    Stephen
    RED One M-X "Lewis" (#791)
    First feature film, Works in Progress, out on DVD (Vanguard Cinema).
    Second feature film, Terminal, now in post-production in Kansas City and scheduled for a late 2013 release.
    Third feature film, Dust, currently in pre-production and scheduled for production during summer 2014.
    Senior Member Brent J. Craig's Avatar
    Aug 2007
    Toronto
    Time code worked perfectly in our tests. Jamming the camera from a Sounddevices 422 and shooting a slate to test. It was always within 1 frame.
    I suspect a lot of the mentions of timecode problems on RU are because there are many frames where the timecode slate numbers are in the middle of updating as the rolling shutter records them. It is very easy to mistake the transition between 3 and 4, for example, to be an 8. In that case, you simply advance one frame and you can read clean code.
    To state it another way, the rolling shutter does not record the image of the timecode slate at a single instant in time, it takes a small amount of time for the shutter to scan the image and therefore a single frame can contain the top of one timecode frame number and the bottom of the next.
  3.   This is the last RED TEAM post in this thread.   #3 Tiemcode
    Red Team Stuart English's Avatar
    Irvine, Ca
    Good point. In my tests timecode is accurate, however you can make a recording of a slate where the numbers look to be in transition.
    So you might like to experiment with SHUTTER PHASE to sync the video frame capture of the camera to the slate display refresh rate.
    Workflow Wizard
    Thank you for your responses. . .
    Would you jam the time code off the camera? Of the 788T? Or off a time code slate???
    Thanks very much.
    Stephen
    Senior Member Emery Wells's Avatar
    Feb 2007
    Ive had problems jam syncing at 29.97 (i.e. would not sync) in build 15. 23.98 has worked perfectly for me.
    Emery Wells @emerywells @KatabaticNY
    Founder/CTO - Katabatic Digital
    KataData iPhone Data Rate Calculator
    http://katabatic.tv
    NYC EPIC Rentals + Scratch DI/Transcoding
    emery [at] katabatic [dot] tv
    Jan 2007
    Melbourne, Australia
    Quote Originally Posted by Stephen Pruitt View Post
    Thanks very much.
    Stephen
    The camera does not currently output TC, so the 788T or the slate would be your master clock.
    Cail Young
    Problem Solver
    Inspiration Studios, Melbourne, Australia
    We shot our first two features on RED the old fashioned double system way. All sync was manual in FCP. It was really not that big of a deal, but it was a few hours every day.
    Now that we have audio enabled on camera, it is so much faster and easier for dailies and off-line edit media transcodes to just transcode the QTs the camera makes if you don't mind being tethered. We find most productions tether anyway for monitor, etc.
    We have a feature shooting now that is doing a very specific hand-held style of shooting and they insisted on NOT being tethered at all. For that film (Toe To Toe) we put a wireless comtec on the camera to get "scratch" audio for dailies and editing into the camera - we are jammin' - but to a Lock-It box attached to the camera. So in final audio post, we can do an auto conform of the original BWF files to the final edit.
    Bottom line, IF you JAM - you should use a Lock-It box (or similar device) so you don't have to re-jam every time you change battery or turn the camera off - that is madness.
    If you are running audio to the camera all the time - there is no real reason to jam.
    And obviously always keep your BWFs from your mixer in case you need to replace the audio recorded by the camera for any reason.
    http://www.gothamsound.com/main.shtm...mid=SAMBLOCKIT
    http://www.pro-sound.com/Merchant2/m...ategory_Code=S
  8. #8 what cabel to use with lockit and red
    Junior Member
    Oct 2007
    hi i own a lockit and might do sound for a short flick shot on red i saw that there is a sort of lemo connector for the red tc in? i used to connect 2 bnc's from lockit to camera?
    i use my 744t to jam my lockit via a lemo>xlr female>xlr male>lemo
    can i ue the same cable to hook up the lockit to the red?
    cheers
    martijn
    Mark Pederson is a true fount of knowledge.
    Amazing.
    Looks like we won't jam. . . here's our plan. . . tell me if it make sense:
    With the 442 and the 788T, we'll have up to 8 XLR inputs: several lavs, a few plants, and a boom or two. All of these signals will be recorded on the 788T.
    Our plan is to tether the camera to the 788T via the four mini-XLR outputs on the 788T, with the four most-likely best audio sources coming out of the 788T and then directly in (line in) to the RED. If we are very happy with those four audio signals, we'll be in like Flynn.
    If, however, we feel that we didn't get the best audio into the RED, we can then manually link the (up to four) extra audio files inside the 788T into FCP in order to get the audio up to snuff.
    Thus the 788T will serve three purposes:
    1) Providing 4 extra XLR inputs.
    2) Recording ALL audio signals all the time and providing back-ups just in the case the RED's audio glitches.
    3) Giving us more than four channels of audio "coverage" should we not like the four channels recorded directly to the RED.
    Make sense, Mark? Anything you'd add?
    Thanks so very much.
    Stephen
    Senior Member michael zaletel's Avatar
    Apr 2008
    Phoenix, AZ
    Thanks for these detailed discussions.
    -shooter
