Click here to go to the first RED TEAM post in this thread.   Thread: LCD issue
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 LCD issue
    Senior Member Harry Clark's Avatar
    NYC
    Very intermittent.
    Sometimes the image on my LCD will "ripple" from bottom to top. Like a wave of magnification.
    Recorded image is fine.
    Build 15.
    Anyone else?
    Harry
    Senior Member Alexis Hanawalt's Avatar
    Mar 2007
    Los Angeles, CA
    Had the same problem. Unfortunately we also ran into HMI flicker which looks the same on the monitor, but is recorded to footage. So, before assuming that the ripples aren't being recorded in the future - make sure there's no HMI present and always doublecheck the footage.
    Alexis Hanawalt
    Bolster Camera, Inc.
    www.bolstercamera.com
    Same here, i guess it's something to do with lcd internal (?) resizing. Because if you zoom in on lcd (round button on the top), it stops
    NYC
    No HMI. Natural outdoor skylight.
    Funny because it seems to coincide with build 15.
    Harry
    Senior Member michael zaletel's Avatar
    Apr 2008
    Phoenix, AZ
    Curious. Is it the LCD or the HDMI out signal? Are people having similar problems with non-Red LCD's or displays?
    -shooter
    In my case, just the lcd. Monitoring over hdmi looked fine.
    Apr 2008
    Phoenix, AZ
    The LCD uses a different out than the HDMI port so perhaps there is a problem with that signal, with that connector or with the cable. Any way to narrow it down?
    -shooter
    To reiterate, i noticed that problem on very fast pans, or in detailed frames, where big part of a frame changes. And only in mode where all menus are visible. When you zoom in on lcd, to the state where you see no menus, it doesn't flicker. So i think it's something to do with internal signal resizing 720 signal to fit 500 or so lines.
    Seems to me like purely software problem.
    Senior Member Eirik Tyrihjel's Avatar
    Oslo, Norway
    I have had the same, even today - it has been brought up in other posts, and I think that it has been stated that this is something related to the firmware, hopefuly it will be resolved in an upcoming version.
    In my case I sometime have some flicker in the lower part of the LCD, and today in daylght I got the flicker on a larger part when adjusting the iris on the lens. It seems to me that it occurs more often when the camera is cold - but that may just be me.
    Like with the above, when I use the 2x magnification or go to the larger screenmode (with less info), it usually goes away.
    It hasn´t showed up on the HD-SDI output, and annoying as it may be, it doesn´t worry me as long as I operate, it is however not a nice thing to have when you have other DPs operating - asking "what is this".
    As other have stated above, I too have no faults in the recorded image.
    RED EPIC-M #646, EPIC-X #250, Scarlet-X P/L #2467 "Harbor", RED ONE #476 MX "MOTHER"
    Commercials | Live | Concerts | Corporate | RED rentals
    Red Pro Primes T1.8: 18,25,35,50,85,100 (all metric), red CF zoom 18-50 T3 (imperial), Red Pro Zoom 17-50mm T2.9 (metric), Red zoom 50-150 T3 (metric) + 300mm T2.8 (imperial) + tons of accessories!
    Leica Summilux-C series on order.
    www.groovyentertainment.com/english/
    Whether you think you can or think you can't - you are right. ~Henry Ford
    NYC
    I saw it on the 720p output as well. Do they all use the same processor?
    Seems likely it's a software bug. Build 13 was fine...
    And the frame was indeed showing high detail; the background was filled with cherry blossoms.
    But to reiterate my issue again; it's NOT a traditional flicker. Its a wave of magnification that scrolls up the screen. The image in that wave gets slightly larger, like it's scaling up. THen the wave passes and it's fine again.
    Harry
