Click here to go to the first RED TEAM post in this thread.   Thread: De-Bayer question...for Graeme
Results 1 to 4 of 4
  1. #1 De-Bayer question...for Graeme
    Dunno if this is a "wait till NAB" thing or not. Its more a question of how Redcine works internally.
    When outputting to a resolution other than the one at which one originally shot the footage, is the scaling part of the de-bayer process?...What I mean is, is there any practical difference between de-bayering to 4k, then scaling in a 3rd party program...After FX, nuke etc... OR is the debayer and scale intrinsically linked within Redcine so as to give the perfect quality of output at your chosen target resolution?
    Hope that made sense
    J
  2.   This is the last RED TEAM post in this thread.   #2
    Makes sense - de-mosaicing is seperate from scaling. As for benefits - no idea.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    I would think that the downscaling quality depends on the algorithm you use. I might expect Redcine to do something like...
    Footage comes in as 12-bit linear (linear as in linear light, not video gamma). De-bayer (footage still linear light). Rescaling could be done in the linear light domain, as it tends to look better when done that way (as opposed to rescaling after you apply gamma correction / gamma curves). The re-scaling step would ideally be GPU accelerated too.
    Whereas if you do the rescaling in another program, there's addition overhead so it'll be slower. As far as rescaling algorithms go, there are different ones out there that are tradeoffs between aliasing, sharpness, and ringing. There are also tradeoffs in visual quality and in performance (a real sinc filter is slow; Shake doesn't do real sinc filtering, it cheats).
    See
    http://www.cambridgeincolour.com/tut...ze-for-web.htm
    2- Mathematically, you might incur some loss due to rounding depending on how you get the 4k image into a 3rd party app. But in practice, this would be insignificant (the rescaling algorithm would make way more of a difference).
    See also
    http://www.fxguide.com/article315.html
    For a similar article from a VFX end-user point of view.
    Bruce Allen
    www.boacinema.com
