Click here to go to the first RED TEAM post in this thread.   Thread: DSMC v6.0.23 Release
Page 5 of 16 FirstFirst 12345678915 ... LastLast
Results 41 to 50 of 160
  1. #41
    Senior Member Tom Greenberg's Avatar
    Oct 2009
    Grand Rapids, MI
    Wow, Dan...hidden talents...and Sean, way to bring out Dan's "good side"!! Thanks to all the development team for this sweet release!
    BRAINCELL CAMERA - MICHIGAN Renting Weapon CF Helium, Epic-W Helium, Raven, Alexa Studio, Alexa Mini
    Primes: Cooke Panchro Classic/i, Sigma Cine, Celere HS, Cooke MiniS4/i, Leica R, Zeiss Contax
    Zooms: Optimo 15-40, Optimo DPs, Cooke 18-100, Duclos 11-16
    Support: Ronin 2, Tero, ReadyRig, EasyRig, Teradek RT FIZs, Teradek Bolts, Bright Tangerine matteboxes, FSI monitors
    Cinematography/Post Faculty, Compass College of Cinematic Arts, Grand Rapids, MI
  2. #42 Sync Port bug?
    Senior Member Paul Kalbach's Avatar
    Oakland, CA
    Quote Originally Posted by Matthew B View Post
    Has anyone sent their side handle in to get the PC sync port put in? I still have the non functioning version in my grip - I'm curious what the process is to get the "gold port" put in?
    Yes. If your sync port is black you need to send it in to have it replaced with the gold one that works. Contact your BS Rep to arrange an RMA.
    I had this done quite awhile ago. I played around with firing strobes during motion capture by programming a button on the Side Handle to Trigger Strobe. Of course it's hit or miss wether the frame is fully exposed or not unless you have a Motion Mount.
    Thanks Red Team for this great update! However, there seems to be a bug now as far as the sync port is concerned. It appears to be stuck in an "always on" state rather than sending just a pulse. When I plug my strobe radio/slave transmitter into the Side Handle, the strobe fires, but won't fire again unless unplugged and replugged because the transmitter is seeing a constant signal from the sync port.
    I would hope that the firmware can be tweaked so that the sync port outputs a trigger pulse simultaneously when the Side Handle record button is pushed while in single frame Stills Mode.
    Paul Kalbach
    RED Weapon-Helium#4580, RedOne-MX #1693, RedOne-MX #10062
    www.ArtichokePro.com
    www.RedZephyrCam.com
    Senior Member Scot Yount's Avatar
    Dec 2014
    Marblehead, Massachusetts
    Quote Originally Posted by William Robinette View Post
    It has always been like this.
    Been like what? Only one map? Or more than one map?
    Forged CF Helium 8K 00107
    Scarlet X 02249 (The Gateway Drug)
    Fujinon Cabrio 19-90 Version 2
    RED Pro Zooms and Primes
    Director/DP at https://www.butcherbox.com
    Living life by the ocean.
    Senior Member Lauri Hakala's Avatar
    Apr 2010
    Finland
    Quote Originally Posted by Scot Yount View Post
    One factory calibration map + one user assignable map.
    Senior Member Robert Gustafsson's Avatar
    Feb 2014
    Stockholm, Sweden
    Thumbnails (clips) finally, so awesome... Is there a way to mark individual clips so they can be viewed as 'marked' in the thumbnail viewer? (A quick way to sort out good shoots and get a quick overview)
    RED EPIC-W #1939
    http://treborian.com
    Jul 2009
    Quote Originally Posted by Stephen Lovett View Post
    Stills - Motion switch working!!!!
    I got wood.
    Steve
    ROFL
    Senior Member vincent kardasik's Avatar
    Apr 2009
    Capbreton, France
    Is there a new user manual coming with this firmware?
    I'm having a hard time figuring how to use the auto exposure and more than that how does it work...
    Weapon CF and Epic-W packages ready to shoot
    DSMC2 Custom Water Housings
    Reel
    L/K-rtel
    Capbreton, France
    Instagram, Twitter and Vimeo
    This is an interesting one:
    A fortnight ago I ran into a serious sensor issue. On the left third the sensor showed in overexposed white parts a white, vertical line that only vanished when I stopped down. Ok. Red's reaction was, send us a log, no better the camera. Fully understandable. Because of many other things that needed attention I postponed the shipping.
    Today I updated the camera and voilá, the white line is gone. My guess is that my Dragon sensor is much better black shaded with this build than with any other build before. When I pulled up sensitivity to ISO 12.000+ the noise is remarkably even and no hidden pattern is visible. Much, much improved than to previous builds. Today evening I will do a noise test. Perhaps the noise also improved.
    I also noticed that camera is running hotter, could be subjective.
    Hans
    Hans von Sonntag
    www.hubbertvonsonntag.com
    Mar 2013
    Quote Originally Posted by vincent kardasik View Post
    Ok, I'm going to be honest, I'm totally confused by the Stills mode, it seems that I can shoot at 25fps at 2:1 or maybe the frame rate doesn't affect the compression anymore?!
    Hi Vincent,
    There is now, under the download section on the RED Store site, an operation guide for 6.0.23.
    One cool thing is the touchscreen access to stills mode as well.
    Thank you very much
    Fury
    Carbon Woven Stealth, RRX, KOWA ANAMORPHIC Full Production RENTALS
    http://www.reduser.net/forum/showthread.php?111020-FOR-RENT-CARBON-FIBER-DRAGON-SO-CAL-AREA-CON-U-S&highlight=Rent+Fury
    949.689.5614 srgtfury@gmail.com
    Thank you very much
    Fury
    Apr 2009
    Capbreton, France
    Quote Originally Posted by Nick Fury View Post
    Hi Vincent,
    Thank you very much
    Fury
    I totally missed that!
    Thanks a lot Nick!
    Reel
    L/K-rtel
    Capbreton, France
