Thread: RED RAVEN - Info and Data Sheets
Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 88
  1. #41
    Nov 2011
    Paris
    RAVEN's Dragon sensor is in the realm of S35 and APS-C sized sensors and that's pretty much what it is.
    +/- 22% ^^
    Senior Member Ben Scott's Avatar
    Mar 2011
    London, UK
    Quote Originally Posted by Ben Scott View Post
    So is everyone in 25fps-land, basically the rest of the world outside the US, missing out on 3:1 compression like 3k on the Scarlet being 48fps but not 50fps and so therefore unusable, or can we all get involved in the loveliness?
    Before this gets lost in a 1000 page thread, does anyone know about this? What is the lowest compression at 4k 25fps?
    2018 Reel
    Instagram
    Senior Member AndreeMarkefors's Avatar
    Sep 2008
    Switzerland
    Been on my mind too. I'm thinking it might be 3:1 too. Worst case would be 4:1 I guess.
    Sep 2008
    Switzerland
    Quote Originally Posted by Gene Sung View Post
    I'm really bad with math, so to figure out what my lenses are in relation to my FS7 (Super 35mm 1.5x crop compared to FF), should I go 1.76 - 1.5 = 0.26
    So an 11mm Tokina would be 11mm x 1.26 = 13.86 mm on the Raven?
    Is that correct? Or is that just totally off?
    11mm on 1.5x is 16.5mm
    11mm on 1.76x is 19mm <-- Raven
    Senior Member Alvise Tedesco's Avatar
    Milan Italy
    Quote Originally Posted by AndreeMarkefors View Post
    11 is 11.
    11 on Raven at 4kHD has approx same fov as 13.2 on S35 1.78:1
    Common focal lengths used on S35 are: 18-25-35-50-85
    Equivalent angles on Raven 4kHD are, approximately: 15-21-29-42-71
    Jun 2014
    Park City, UT
    Any news on the v mount base expander weight? For me a big appeal to this camera is the weight. But without a power port built into the body you cant use the camera stripped down to the bare bones. Is there any talk of just a power module? All i need is power port so i can run a battery as counter balance on glid cam or on my belt.
    Phil, any mention of the bird's power draw in your chat with Jarred?
    Trevor Meier :: Story & Image
    http://trevormeier.com/
    http://storyspark.ca/
    GEMINI #09
    Epic-W, Raven, Epic Dragon
    Proud owner since Red One #182
    May 2007
    North Hollywood, CA
    Well, if they made it with PL mount I'd buy one, as I already own the lenses. No PL mount means I'll spend my money elsewhere.
    www.kfwright.com
    Teradek Bolt 600 HDMI/SDI (1 TX 2 RX)
    Sony CineAlta PL lens set: 20/25/35/50/85/135
    Hedge data management
    Foolcat and Foolcontrol user
    Quote Originally Posted by Trevor Meier View Post
    Nope, but since RAVEN is using a 4K Dragon sensor rather than 6K or 8K, I imagine there could be some power savings.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Phil, in some forums some people say 120fps@4k 13:1 will be really noisy. what do you think?
    Also, do you think they will keep the anamorphic mode locked ?
    Thanks in advance,
    cheers
