Click here to go to the first RED TEAM post in this thread.   Thread: DSMC-2, The Weapon, The Scarlet-W and the Raven and the improvements that they bring.
Page 1 of 20 1234511 ... LastLast
Results 1 to 10 of 197
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 DSMC-2, The Weapon, The Scarlet-W and the Raven and the improvements that they bring.
    Fire Chief Jarred Land's Avatar
    I have noticed in a few threads over the last couple days a lot of people asking alot of questions on what the improvements are with Weapon and DSMC-2 System, which means we probably should list them all in one thread to make everyone's life easier.
    The top highlights I think most of you know:
    -Built-in-ProRes ( and another format coming soon )
    -Lower REDCODE Compression ratios
    -Auto Sensor Calibration
    -3D lut support
    -Built in Wifi
    -Lower Weight with an improved mechanical design
    -3rd party module support
    I thought I would take a few photos and highlight some of the other improvements that we talk a little less about.
    With the Introduction of the Scarlet-W on Thursday, There are now 5 RED cameras that share the new DSMC2 Body. From left to Right below, The 6K Weapon MG, The 6K Weapon Carbon, The mighty 8K Weapon ( Forged ), The 5K Scarlet-W , And the 4.5k Raven.
    The DSMC2 RED Dragon Sensor related improvements:
    All the RED DSMC2 Cameras share the same Dragon pixel design that most of you know and love, applied in various sizes and configurations.
    On the DSMC2 system, The Dragon gets to perform better.
    The Dragon Sensor in the new system is surrounded by brand new everything. Better sensor board designs, better components and better connections between them make for a noticeable improvement in image quality, From the highlights to the noise floor, improved sensor streaking, and better control of temperature variances. We also designed a completely new sensor cover glass to squash out a lot of the flare and improve that last level of defense against IR contamination.
    Phil Holland did a great test that shows the bounty of all these improvements over here: http://www.reduser.net/forum/showthr...itude-Examined
    RED ASIC Improvements
    Most of you know that we make our own sensors, less of you know that we also make our own ASICs. ASICs are the the processors inside the cameras that put everything together, and we make a few different ones to do different things. In cameras, it is easy to 2 of the 3 things. Resolution, Dynamic Range, or Frame Rates. To do all 3 like RED cameras system do, it is incredibly difficult. You need an incredibly talented team of engineers that can make incredibly talented sensors and you also need incredibly talented processors to keep up with them.
    Making your own Processor ASIC is incredibly expensive, resource draining, and very, very, time consuming .. which is why most companies just use generic processors ( and rebrand them as their own ) or use generic FPGAs . Nothing wrong with that.. but you get stuck with " good enough " rather than exceptional. When you make a industry surpassing sensor, you need mate it to something that doesn't cripple everything.. which is why we make our own ASICs.
    Here is a photo of one of our ASICs in wafer form. Might be boring to some of you.. but these ASICS are a work of art. They have dozens of layers of magic in them and they ones in the DSMC2 cameras are stupid fast. It is how we can offer so much more bandwidth and do so many things all at the same time.. i.e 8k resolution at a bat-shit-crazy-75-mother-fucking-frames per second.
    This isn't a step or a skip or leap above anything else.. This is a get-in-a-rocket-ship-to-the-moon kind of jump.
    Cooling System improvements:
    More like a complete redesign rather than an improvement.
    When you put 4k or 4.5k or 5k or 6k or 8k into a camera the size of the Epic/Weapon/DSMC2 camera, your quite literally playing with fire.
    On DSMC2, we changed the fan intake from the front to the top and the exhaust from the top to the bottom back and reversed the entire flow of air.. and sound, away from whatever it is your shooting. This one personally surprised me, and I actually would of bet money on it not working in reverse , as my armchair-backseat engineering- google searching head just always went with the " heat rises " concept. I was dead wrong. The new cameras run cooler, quieter and the sound guys get a lot less offended.
    OLPF Improvements:
    This is another piece that has had a lot of work done. The Swappable OLPF system that we introduced with the Epic Dragons really has been an exciting opportunity for users to tweak their cameras to different shooting conditions and Creative styles. We have an array of filters available and 3rd parties like John Marchant's Kippertie filters give a plethora of creative possibilities.
    The OLPFs in all of the DSMC2 bodies that have a swappable OLPF ( all except the Raven ) Have a new design as well.
    The DSMC2 OLPFs are now " Smart " meaning that the camera knows which one you have in your camera so you don't need too change that in the camera menus every time you change filters.
    Also we did away with those 4 little pain in the ass screws and developed a quick release system that ejects the filter with one turn of a single allen key. Since we moved the quartz off of the OLPF and onto the Sensor Glass, alignment of the filters also has become less critical for those less than ideal field changes.
    Two RED monitor ports on the brain instead of one, and no monitor cables (if you don't want them).
    The Epic and Scarlet have a single monitor lemo on the brain and to get another RED monitor you need to add a specific module. The DSMC2 system has 2 new ports on the brain one on the top and one on the side, that allow you to direct connect a combination of RED LCDs or EVFs in various configurations without cables getting in the way or cable failure ruining your day. You can still use the DSMC2 Lemo Adapters if you do want to run one or two of the ports to an offboard monitor or EVF, you get it both ways.
    Internal Scratch Microphones built in, and a redesigned back focus adjustment .
    The Microphones on the front are pretty self explanatory, but the new Sensor adjustment for back-focus is a hidden little jem. It has been repositioned below the front logo coin, away from top plates and monitors and easy to get to when you want to, and easy to get to when you don't.
    Senior Member Kemalettin Sert's Avatar
    May 2009
    Los Angeles CA
    All those images shot on Weapon 8K :)
    EPIC-X DRAGON 7424
    Senior Member Scot Yount's Avatar
    Dec 2014
    Marblehead, Massachusetts
    Now we talkin'...
    Forged CF Helium 8K 00107
    Scarlet X 02249 (The Gateway Drug)
    Fujinon Cabrio 19-90 Version 2
    RED Pro Zooms and Primes
    Director/DP at https://www.butcherbox.com
    Living life by the ocean.
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    Quote Originally Posted by Kemalettin Sert View Post
    Yes indeed, I shot them all last night on the Weapon 8k With Zeiss Compact Zoom 70-200mm glass :)
    Junior Member
    Jan 2013
    Canada
    It's wonderful you really improved the DSMC-2 body design to both get the best from the new sensor technology and address some of the issues shooting with the previous line of cameras. Something as simply as not having cables, brilliant! You guys really got the details right. Thanks for the succinct breakdown and photos, and the smaller camera line-up.
    Banned
    Jan 2013
    Does Red have it's own Sensor fab? I thought Red only designed the sensor...
    Mar 2011
    Toronto, ON Canada
    Thanks Jarred. I've been on the fence about upgrading my Dragon (because it so good), but posts like this keep me wanting to do it.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Oct 2013
    "OLPFs in all of the DSMC2 bodies that have a swappable OLPF". Is there going to be an IR DSMC2 OLPF for the Scarlet Monochrome?
    Wow. That's a nice overview. And a lot of info most companies wouldn't publicly talk about.
    I think one other topic to make note of is the concept of modularity.
    A lot of people were surprised that no DC, HDMI, or HD-SDI was included on the camera from the get go, but if you think about common points of failure during 1-5+ years of daily camera use (damaged ports and cable snags) I think it makes a lot more sense because you'd likely only be down a module and not have to send the entire camera in for repair.
    The combined effort to me is essentially the evolution of the DSMC concept. More optimized. More modular. The ability to strip the camera way down if you need it. I always say it's impossible to make a big camera smaller, but it's very easy to make a small camera larger. I've taken Weapon rigged with just a couple REDVOLT XLS and just the DSMC2 REDVOLT XL Module attached to the brain and hiked up to grab some vistas. It's crazy how lightweight that can get.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Jonathan Stevenson's Avatar
    Nov 2008
    Denver
    Ugh, that 8K is so sexy...
