Thread: Ronin and weapon
Results 1 to 7 of 7
  1. #1 Ronin and weapon
    Nov 2008
    Dallas, TX
    Can I use a ronin with weapon, Anton 90w brick, rt motion focus and ghost eye wireless all mounted on cam? Will it balance? Also 40mm kowa prime lens...
    JAKE WILGANOWSKI
    Director of Photography / Filmmaker
    CINE-AUTOMATIC.COM
    Jun 2013
    Cyprus
    Yes, you can. All my bricks for Ronin use are Slim profile. 70-90w. Its goof for up to 7kg.
    If you dont keep your center of gravity on Y axis you might have a problem tilting up and down, but so far my EPIC & ROnin have been a perfect match.
    RED EPIC DRAGON #8131
    Nov 2008
    Dallas, TX
    Will i be ok mounting the battery on the back not the side?
    JAKE WILGANOWSKI
    CINE-AUTOMATIC.COM
    Jun 2013
    Cyprus
    The slim one yes, however i still manage to work with 180wh ones but whenever i dont tilt up and down much. It depends on your lens length/weight and your RFF setup.
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Dallas, TX
    Look at be products offered by Cinemilled...they have extension arms that enable you to mount full size bricks on the back of the camera while still having full tilt control. Get the pan extension and the regular extension arms. You may also want to pickup their cheap ronin dovetail plate which gives you more fore/aft range.
    Chris McKechnie
    Email - redepicguy@gmail.com
    Reel - https://vimeo.com/314919326
    Nov 2008
    Dallas, TX
    Chris how well does it work with the readyrig
    JAKE WILGANOWSKI
    CINE-AUTOMATIC.COM
    Mar 2011
    Dallas, TX
    I don't own a ready rig...but something to remember is the RR doesn't limit vertical movement..it essentially just distributes the weight over your back. Whereas the Exhauss, Tilta Armorman, and Easy Rig with their full serene setup does help/alleviate some of it.
    Chris McKechnie
