Click here to go to the first RED TEAM post in this thread.   Thread: New Build 16 features...
Page 1 of 16 1234511 ... LastLast
Results 1 to 10 of 157
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 New Build 16 features...
    Red Leader Jannard's Avatar
    In anticipation of the eminent release of Build 16, here is a list of the improvements and added features:
    IMPORTANT NOTE: You MUST do two upgrades in sequence to change to Build 16. 1st is a pre-build firmware upgrade, then the actual Build 16 upgrade. Instructions will be clear. Follow them carefully.
    Major Features of Build 16 firmware.
    * New .R3D file format - requires the use of new versions of QuickTime Component, RED ALERT and REDCINE (not currently available)
    * Digital Signal Processing optimization.
    * Image Compression Optimization.
    * Support for 4K 16:9 recordings in REDALERT and QuickTime based applications.
    * Fixed high detail scene codec errors in 4K 16:9 recordings.
    * Fixed polarity of audio recording relative to MIC and / or LINE inputs.
    * Improved audio sample to video frame synchronization (lip sync accuracy).
    * Reduced RED-LCD display tearing on last few lines in 4K record / playback.
    * Addition of REDspace and RAW viewing modes.
    * Updated file name structure to eliminate duplicate file names.
    * Addition of Pre-Record (10 sec or 30 sec loop) mode.
    * In-camera 1080p playback of REDCODE RAW .R3D files.
    * Improved display precision and color response of RED-EVF and RED-LCD.
    * Seperation of Sensitivity (ASA) and Exposure (Compensation) parameters.
    * Extended exposure times of up to 1/2 sec enabled in TIMELAPSE menu.
    * Added RED-EVF control over Audio, Shutter, ISO and Varispeed parameters.
    * User programmable Tonal Response Curves menu.
    * Look Around available on HD PREVIEW outputs when LCD and EVF are active.
    * Improved video Genlock (Tri-Level Sync) lock for 23.98, 24.00, 25.00, 29.97.
    * Added 1.85 and 2.40 Safe Action and Safe Title Protection Guides.
    * Improved indiction of image magnify mode with new "X" cursor
    * User programmability of A, B, C keys and USER 1, 2, 3, 4 keys
    * Allow return to last menu position before exiting menus, when SHIFT-SYSTEM is pressed
    * Disabled auto-reset of reel counter on change of project time base.
    * Decreased boot time. Roughly 68 seconds.
    * Also need new FCP Log & Transfer plugin (will be available soon)
    * Red Alert will not loose audio tracks when re-generating QuickTime reference files
    * QuickTime codec now supports full resolution reference files and full render quality output
    Jim
    "The camera is arguably one of the most important of all inventions… it is the single tool that has the ability to stop time, record history, generate art, tell stories, and communicate messages that transcend language like nothing else ever conceived."
    "Everything in life changes... including our camera specs and delivery dates..."
    We reserve the right to refuse service to anyone with a bad attitude.
    Any word on 3rd party support for native .R3D files, besides Scratch?
    If it's not difficult, why do it?
    Frontline Infantry Christian Edwards's Avatar
    Aug 2007
    London/Sydney
    I see your elves have been busy at work ,this is way to much to take in ... of coarse this all means nothing to me until i get my camera
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    Quote Originally Posted by Kenn Christenson View Post
    As I have stated on other threads, we are working on the SDK now. No dates, but soon.
    I can't speak for the 3rd parties as to how long it will take them to implement, but several seem pretty motivated.
    Jim
    Singapore
    now we know why it's taken so long....and from the list I see....worth every minute of the wait...
    what an amazing feat! thanks fer the effort!
    So now new Redcine and SDK development!
    Cheers!
    http://www.techyoumedia.com
    Senior Member Joe Vinson's Avatar
    Wow! When you guys say "we're listening," you ain't kiddin'.
  #8
    Fire Chief Jarred Land's Avatar
    Quote Originally Posted by Khristian View Post
    I see your elves have been busy at work , camera
    you would be surprised if you knew how much work Jim personally put into the development of build 16.. He outlasted us many of nights....
    Senior Member IAN SUN's Avatar
    Canada, Jamaica
    I hope you will be able to get some sleep now : )
    .........Ian Sun..........
    Anansi Moving Images
    EPIC X 00498 Baby!!!
    MX RED ONE 1080
    p+++
    ....... T O R O N T O .......
    Senior Member Michael Grugal's Avatar
    Sep 2007
    Burbank, CA
    This is exciting. Thank you Jim, thank you RED team.
