Thread: DNxHD 36 changed to DNxHD SQ/HQ? Please help.
Results 1 to 5 of 5
  1. #1 DNxHD 36 changed to DNxHD SQ/HQ? Please help.
    Nov 2013
    Glasgow
    Hi All,
    I recently updated RedCineX for the first time in a while.
    I noticed in the export page Avid DNxHD 36 8 BIT format has gone and been replaced with DNxHD SQ or HQ or LB or HQX.
    I have always transcoded to 36 8bit and wondered if anyone knew what these new formats meant and which one I should use.
    Many thanks in advance.
    Dec 2009
    Hollywood, USA
    Here's a run down of DNxHR bitrates:
    marc wielage, csi colorist/post consultant daVinci Resolve Certified Trainer
    Junior Member
    Jun 2010
    Hi guys,
    As James said the new version of RedCine X has done away with
    DNxHD 36 8-bit
    and now has the following
    DNxHD HQ
    DNxHD SQ
    DNxHD LB
    Does one of these correspond to DNxHD 36 8-Bit?
    The list you've posted Marc is for DNxHR (4K and UHD) not HD.
    RecCine X DNxHD changing in the export menu from DNxHD 36 8Bit
    Avid's chart is available here.
    http://avid.force.com/pkb/articles/e...Specifications
    They list the data rates in MegaBytes/Sec instead of MegaBits/Sec. If you multiply by 8 you will see numbers close to what you are used to.
    The DNxHR LB is supposed to be similar to DNxHD 36 8-bit.
    Dec 2009
    Hollywood, USA
    Thanks for the update, John -- I'll add that to my files. It does look like DNxHR LB is pretty much the new "DNxHD 36."
    Note that only HQX and 444 have 12-bit color. The files aren't that big (assuming you've got enough storage), and I could see finishing an entire project in this format provided you had to deliver it quickly, like for a reality show or a daily news show.
Tags for this Thread
View Tag Cloud
