Thread: 4:2:0 to 4:4:4???
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 4:2:0 to 4:4:4???
    Banned
    Apr 2008
    Can you convert footage shot in AVCHD at 1920*1080 in 4:2:0 to 960*540 at 4:4:4??????How do you do it?
    Would the image look better?
    hi - you probably can but it will be 4:2:0 data into 4:4:4....so it will still be 4:2:0 if you know what i mean.....you are going the wrong way up the resolution tree.
    it will still look good - what's you delivery format and waht are cutting on?
    Senior Member Peter Majtan's Avatar
    Feb 2008
    Japan
    If You are asking if it looked better the downscaled 960x540 as compared to a 960x540 crop from the original AVCHD - of course YES. Otherwise it is a tricky question and very subjective one. What I would do is to convert the 1920x1080 4:2:0 AVCHD to uncompressed 1920x1080 4:4:4 as soon as I have the footage off the original media (not gaining any quality at this point, but also not loosing any) and then keep my DI fully uncompressed. This will guaranty the best possible results, but it will be "little" heavy on resources...
    You don't need eyes to see, You need a vision!
    www.petermajtan.com
    Feb 2008
    Japan
    Wayno - this is not entirely so. If You are having half the chroma samples at 1920x1080 and You have scaled the footage ti half of its size it will essentially become 8:4:2 (if there was such a thing) which would transpire to perceivable 4:4:4 - of course You will have to get out of the AVCHD codec...
    www.petermajtan.com
    Banned
    May 2008
    without calculations, i think u have to downsample twice and even then and even in a really high bit u still wont get perfect colors,(maybe 1.65-1.85) of what the 4:4:4 image would be (if u had 4:4:4 and downsamlpled to 4:4:4)(not adding the compression from the codec).
    the image will alter a little from the original when changed to 4:4:4, but as mentioned before, it would make a significant improvement if done before the start of the post.
    Banned
    Apr 2008
    So how do you do it?
    Do you convert the 1920*1080/4:2:0 footage to 4:4:4 and then you simply resize it to 960*540?
    4:2:0 means that blocks of 2x2 pixels contains average chroma information.
    So if you convert this 2x2 pixels to one pixel you get 4:4:4 but half resolution.
    But couldn't you let's say apply an improved algorithm when resizing the luma information(the bicubic algorithm for example) and another one for chroma to pull all the info from it?
    Why would you want to do this? Sure, you end up with 4:4:4 video, but you're getting there by throwing away luma resolution, not by adding chroma resolution. At a given viewing size, the 1920x1080 4:2:0 you started with is going to look better.
    You should follow me on Twitter here.
    Banned
    May 2008
    it wont be accurate, it's not about the #s, it's about what would be stored in them.(if the image had already an average assumption to a 4:2:2 and then another assumption into 4:4:4, the image wont be the same as the 4:4:4 image re-sized, so it wont be accurate or real 4:4:4), sometimes u cant even do it in a colorful scene, it would mess it up be changing some colors in parts of the screen and not others(or diff degrees), other than the fact that the whole image would shift colors.
    u cant get info that u don't have, but u can improve info that would be applied in post.
    Banned
    May 2008
    exactly
    Banned
    Apr 2008
    Isn't color correction,chroma keying, digital composing,etc. better done at 4:4:4:????
