So, I am trying to use a 720p Sony Bravia moniter which has HDMI input and RGB input. The model number is KDL-20S4000, SN-1602223. I am having no luck at all getting any signal to the monitor. I am assuming, since the camera has a constant live feed through the HDMI, that it is a monitor issue. Also, I am on a local feature in Kazakhstan, and the monitor was bought locally, maybe that would be the issue. Do monitors have certain regions and devices they work with, like DVD's? I seems to be an American version because all the stickers and menus are defaultly in English. We have about a 35 ft. HDMI cable, does anyone foresee the length of the cable being a reason for no signal? I have tried going straight from HDMI out to HDMI in, no signal. I have tried going from HDMI out to an HDMI-DVI adpapter to a DVI-RGB adapter into the RGB input on the monitor, no signal. I am almost at a loss, I guess I just need to try another monitor. I don't see why HDMI to HDMI won't simply work. Does anyone have any suggestions or answers? Also, is there a list somewhere of consumer monitors tested, used and known to work through HDMI on the RED?
Thanks for anything,
Tanner
Staussproductions@yahoo.com
