Thread: GROUP BUY - Tilta Nucleus-M Wireless Follow Focus
Page 133 of 143 FirstFirst ... 3383123129130131132133134135136137 ... LastLast
Results 1,321 to 1,330 of 1423
  1. #1321
    Senior Member steve green's Avatar
    Jan 2012
    Thousand Oaks, Ca
    Spent some more time today and got the focus, iris, zoom working perfectly. Still can't get the Red start/stop cable to work at all.
    Senior Member Wil Wong's Avatar
    May 2012
    Toronto, Canada
    I had issues getting the start/stop cable to work too. Are you using the V-lock I/O Expander module? I have that and it didn't work for me BUT it worked on a colleagues module that isn't the v-lock i/o expander.
    Movme inc.
    Red Epic-W s/n 4015, 8K Digital Cinema Camera
    MacBook Pro 6 core, FCP-X
    DJI Ronin, Ready Rig, Vaxis 500+, Tilta Nucleus-M, OSEE HSM-700, Dynacore Mini
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    Quote Originally Posted by steve green View Post
    Same. Using the V-Lock IO Expander.
    I'm going to see if they actually want to make good on their extra Rec/stop cable promise and ask for a 3 pin Fischer since I have their DSMC2 top plate.
    Senior Member Daniel Stilling's Avatar
    Dec 2009
    US, Denmark
    For me, both the RED cable and the 3 pin Fischer (through Tilta top plate and WC D box) worked without an issue. Did you go in the cameras menu, and fiddled with the communications menu? I'm not sure what the right setting is, but I did change a couple of parameters in there...
    Daniel Stilling, DFF (Danish Society of Cinematographers)
    Director Of Photography
    www.danieldp.com
    this might have something to do with the R/S cables not working:
    https://mediablackout.net/blogs/news...igger-protocol
    Nicholas JS Wise
    DP & Gimbal Op
    cinenick.com
    DSMC2 Monstro w/ full production package
    HELIX PRO gimbal w/ ReadyRig exo
    Universal monitor/rx system for Teradek RT FI+Z
    Protective cap for the DSMC2 EVF mount's Lemo port
    Gold/V-mount battery plate for Letus35 Helix gimbal
    Senior Member Jens Jakob Thorsen's Avatar
    Denmark
    The V-lock IO has a different trigger than the older modules
    Jens Jakob Thorsen DFF
    Director of photography
    Denmark
    www.jensjakob.com
    mail@jensjakob.com
    Monstro VV
    Oct 2013
    Tucson, AZ
    Figured it out. Thanks, Daniel.
    For others:
    Menu > Settings > Setup > Communication > Serial
    Change Ctrl Protocol to RED Command Protocol.
    Edit: RED Camera menus, not Nucleus-M menus.
    Senior Member David Ellison's Avatar
    Apr 2009
    Manchester UK
    Aaron which unit have you found this in? I don't see your directions in the menus of the handles, motors or the Fiz unit.
    David J. Ellison | Writer/Director - Cinematographer - Editor
    __________________________________________
    davidellisonfilms.com | reverefilms.co.uk | iaithemovie.com
    | insta - davidellisonfilms
    May 2012
    Toronto, Canada
    David, you’ll find the menu rcp settings in the camera. When the cable is plugged into the ‘Ctrl’ plug, the start/stop works.
    Movme inc.
    Apr 2009
    Manchester UK
    Many thanks!
Tags for this Thread
View Tag Cloud
