Thread: Custom RTMotion Monitor/Rx mount w/ power distro, rosette grip and LED arm
Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 74
  1. #1 **PRE-ORDER** Universal Monitor/Rx mount for RTMotion- LIMITED RUN
    Visit cinenick.com/rtm to learn more and sign up.
    I have had my RTMotion system since early 2014 and it has been indispensable, especially for gimbal and handheld work. The new Latitude modules are pretty dope too.
    A couple months back, I sketched out an idea for an integrated monitor mount system. Eventually, it became the prototype you see here. Thereís only a few minor tweaks left to do and then it's off to the machinist.
    I am still working out pricing, but if you are interested in a pre-order, I would love to hear from you - please indicate your interest below with the type of power cable you would need (mini-XLR4 for TVLogic, dummy LPE6 for SmallHD 502/501 or dummy L-series for TVLogic's with attached batt plate or SmallHD Focus).
    FYI, the ones you see here are resin and nylon prototypes. The production version will be CNC'd from Aluminum 6061 and type III anodized in black.
    BASE UNIT
    - screws to rear of hand controller
    - locking L-series battery plate
    - sends power to monitor and wireless video receiver via included Power Y-Cable
    - powers hand controller via dummy LPE6
    - houses control circuit for powering LED arm
    - thin light profile, with styling to match hand controller
    SIDE MOUNT
    - Arri rosette for attaching left grip
    - rosette axis matched to focus knob axis for weight distribution
    PIN-ROSETTE ADAPTER **NEW**
    - attaches to side mount
    - mounts to regular light stand's 5/8" baby-pin
    FRONT HARNESS PLATE **NEW**
    - features tactical-style swivel stud for hooking on lanyard or neck-strap
    TOP MOUNT
    - Arri rosette for attaching monitor/rx mount
    - ratchet-style M6 knob
    MONITOR/RX MOUNT
    - viewer angle adjustable via rosette
    - supports monitor and wireless video receiver
    - captive 1/4-20 screws (5/32 and slotted)
    - removable anti-rotation pins for SmallHD monitors
    - anti-slip rubber pads
    LED ARM
    - Bright White or Tactical Red illuminationation modes
    - connects with Lemo and locks via captive screw
    Shout out to Mike Gailing @ Teradek, Jin Lee @ TVLogic and Jon Walsh @ Anton Bauer for helping me with this project. And to Rich Hawkes @ RTMotion for the demo unit while you repaired my screen.
    Nicholas JS Wise
    DP & Gimbal Op
    cinenick.com
    DSMC2 Monstro w/ full production package
    HELIX PRO gimbal w/ ReadyRig exo
    Universal monitor/rx system for Teradek RT FI+Z
    Protective cap for the DSMC2 EVF mount's Lemo port
    Gold/V-mount battery plate for Letus35 Helix gimbal
    UPDATES
    12/1/17
    - Better machining quotes = new pricing options
    - Voltage LED Display option
    11/16/17
    - Narrowed/improved wooden grip design for better microforce knob accessibility
    - Finalizing neck-strap plate design
    - Finalizing new top locking plate (for heavy monitor/rx combos)
    - Improved LED arm design
    - Better overall weight saving design
    10/14/17
    - Cable retention strengthened in base unit
    - Design testing for neck-strap plate
    10/6/17
    - New prototype arrives for build and testing
    10/2/17
    - Paralinx receivers from the Tomahawk v2, Ace and Dart systems confirmed to be compatible
    9/30/17
    - Light-stand baby-pin/rosette mount created
    - Base unit strengthening redesigned
    - Top mount strengthened and reshaped for better clearance
    - Monitor/rx mount strengthened and redesigned to include lateral 1/4-20's for more device compatibility
    - Regulated 5V USB cable option added for when using iPhone apps like foolcontrol or Vuer
    - 3.5/1.35mm barrel option added for Paralinx Arrow/Arrow+ receivers
    Nicholas JS Wise
    DP & Gimbal Op
    cinenick.com
    Senior Member PC Greene's Avatar
    Sep 2010
    Chicago, IL | Worldwide
    I'm in for use with a SHD702 (LP6 battery killer) and Paralinx Tomahawk RX (2 pin Lemo) and / or Latitude M. Thank you!
    PAUL CHRISTOPHER GREENE
    director | Local 600 DP | composer
    Chicago, IL | worldwide
    www.paulchristophergreene.com
    RED Epic Dragon - MoVI - Helix Seal Team - Proline Raven Steadicam "AR" Config. - Modifed X-Fold UHL 55 pound FAA 333 UAV
    Zeiss, Leica, Canon primes & zooms - RT Motion 2 motor force joystick FIZ, Paralinx Tomahawk
    nMac Pro, Adobe CC, Media Composer, Devinci Resolve, AVID Protools surround studio +
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    Interested.
    Very interested. Are the cables removable? It looks like there's 2 Lemo out. Is that right? Also, is there any way you could check compatability with Boxx Atom? I believe they use Hirose connectors for power.
    Senior Member Eric Oh's Avatar
    Nov 2012
    Barcelona / Toronto
    Totally interested but would prefer to keep it monitor agnostic if possible as in my situation ACs would provide the monitor of their choice. Is that possible? As for the wireless Iím currently still using my Paralinx Arrow Plus as Iím waiting for Teradek to release their DSMC2 integrated Bolt transmitter.
    Eric Oh, CSC
    Cinematographer
    www.vimeopro.com/ericoh/dop
    www.instagram.com/ericoh_csc
    Monstro | Komodo ST | Sigma Cine Primes | GL Optics 70-200mm | Clavius Lenses
    Junior Member
    Oct 2015
    Paris, France
    Interested !
    Senior Member Linda Barzini's Avatar
    Dec 2009
    Chicago
    Any chance of another version for Bartech?
    Aug 2007
    Could you make a plate for this battery? It's a really good one (small and powerfull).
    Apr 2009
    UK
    Holy crap, that’s really good!
Tags for this Thread
View Tag Cloud
