Thread: Call for better audio recording on newer RED cameras.
Page 9 of 9 FirstFirst ... 56789
Results 81 to 88 of 88
  1. #81
    NJ
    https://www.sonosax.ch/category/news/sononews/
    Thread discussion: http://www.reduser.net/forum/showthr...n-SONOSAX-M2D2
    Looks like it falls in line with some of what people have been suggesting for achieving better in camera audio.
    Take the insides of a device like this, add 2 more inputs, and put it into a new gen RED Audio module.
    Will instantly have decent RED audio that is more streamlined into the camera system and less frankensteined.
    Brian Timmons
    BRITIM/MEDIA
    San Diego, CA
    Can anyone confirm that the RED RedVolt Expander with 2 XLR inputs records clean sound? If so, the real issue is the form factor of the RV expander. I agree with the idea that RED left the door open for 3rd parties to meet the needs of RedUsers with options suited to multiple shooting styles. Good concept, but problematic in practice - long development timelines, customer price sensitivity and modest sales volume is hardly a capitalist dream scenario.
    As noted previously, the crucial message to RED is perhaps more about deep engagement with respected 3rd party partners well in advance of the debut of DSMC3. The timeline for release of modules for DSMC2 meant a huge percentage of buyers went with the Base Expander so they could start shooting right away. Many RedUsers, myself included, just assumed that a more evolved module with key features - whether from RED, OH, etc - would come along and offer enough added value to justify the spend. If an OMOD with the particular feature set I was looking for had come out in 2017 I would have snapped it up. Unfortunately for me, Mark targeted specific use cases that he had reason to believe would be popular instead. Not a criticism, it's what any rational vendor would do when rolling out a new product line, just didn't happen to suit my needs.
    IAC, I'm really attracted to the little Sonosax M2D2 but really wish it had a little SD card recording capacity upstream from the camera's audio section. It would provide redundancy and potentially save you if there was any issue with the signal path into camera. Yes, for the umpteenth time, a proper sound person with their own recording facility is what any smart producer should do - but that's a different thread.
    Cheers - #19
    Junior Member
    Apr 2016
    Richmond, VA
    I have and use the RedVolt Expander all the time with perfect audio. It certainly helps to have a good feed from a professional sound opp person's mixer. However, I've used the audio straight in from a quality boom mic many times for interviews and such. I've even done side by side comparisons with the audio tech's files recorded from their mixer and could not tell a difference from the r3d's audio in post.
    Of course I'm not recommending for large scale productions for high end broadcast commercial or film work. But for most internet delivery or even low budget film work I think the RedVolt is a great solution.
    RED Epic-W Helium 8k
    Junior Member
    Jan 2013
    Washington, DC
    Quote Originally Posted by Brian Timmons View Post
    4) Clean audio with no digital pops, hiss, or other phenomena that contaminates the signal.
    (according to some user reports)
    Brian Timmons
    BRITIM/MEDIA
    I get these digital pops and hiss with every pro audio setup I can think of on both my Weapon and Raven.. I'm not sure if I have a bad DSMC2 Base Expander or if DSMC2 audio was not intended to be used. There are less "pops" if I use a 302 mixer or a Tuscam mixer/recorder combo as the preamp. If I connect the battery powered mics directly to the RED (without using a preamp) the audio pops are so bad it is unusable. This is unfortunate, bc lately we had our sound department cut- I've been one man banding news packages with no time/resources for dual system audio.
    Junior Member
    Apr 2016
    Richmond, VA
    Quote Originally Posted by Matt Fredericks View Post
    Are you on Firmware 7.0.1? This was a known issue (I personally had this issue), and it was fixed in version 7.0.2 or 7.0.3 if I remember correctly.
  6. #86 Abox and Helium noixe
    Junior Member
    Dec 2018
    I too am having issues with noise coming across the Abox into my Helium. Having to record to an audio recorder and sync in post. Not the end of the world, but a time killer when time is money in post.
    Using Lectro Wirelesses and NTG3 powered mic.
    Curious if this is also a problem with the Production Module that has the built in XLR? May have to spring for it, but it would increase weight on my camera and I'm trying to go as light as possible as most of my stuff is run and gun docu style.
    Oct 2014
    Auckland, New Zealand
    Quote Originally Posted by Marc Womack View Post
    If you at least use timecode then that should reduce the time spent to a snap of the fingers.
    http://IronFilm.co.nz/Sound/ (Sound Recordist based in Auckland, NZ. Happy to travel too)
    https://www.youtube.com/c/SoundSpeeding
    Senior Member Michael Lindsay's Avatar
    London UK
    if the A-box desont have a in-line ground loop isolator built in it is pretty much worthless bulky junk IMHO.... DSMC2 needs a ground loop isolator for many Audio situations...
    How do you power you Lectro RX?
