Thread: Thoughts on 8K Epic w vs. 5K Epic Gemini?
Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
  1. #1 Thoughts on 8K Epic w vs. 5K Epic Gemini?
    Dec 2014
    Being somewhat of a newbie to Red cameras I didn't pay much attention or understand the S35 8K sensor and cropping that happens when shooting at lower resolutions. I find myself not shooting much at 8K right now. If I understand correctly if I shoot anything lower than 8K res let's say 5K, I am using less of the s35 sensor surface than let's say if I was using the Red Gemini shooting at 5K utilizing the full sensor surface and getting less noise and more clarity. So I kind of feel maybe the Epic w 8K was not the best choice for me to go with when I am not shooting everything in 8K. I also wanted something a little more future proof if such a thing, but even if 8K resolution were main stream right now, I feel the Epic w is still very limited in what it can do option wise since it will only record in 30fps or so. Thoughts?
    Red Monstro 8K VV | Red Gemini 5K | Kippertie Revolva
    You are thinking it wrong.
    When shooting red you have a lot of options. Even if you want HD end result you shoot full sensor, if you feel files get heavy you simply apply more compression. So the number of k´s and the weight of the files are not really linked to each other.
    Also you can record 4k downsampled prores files from the 8k sensor.
    But still, gemini is a pretty sweet option. And I think I would actually rather have it then a Epic W.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
    Senior Member Michael Lindsay's Avatar
    London UK
    We tested a Gemini against our monstro and will probably get one... really versatile tool, easy to use and it is great not to crop for slowmo.
    (we passed on helium as we felt, although impressive, it a little too niche... but the Gemini seems like a much more generally useful tool)
    Ps Also a great Anamorphic camera..
    Dec 2014
    Quote Originally Posted by Björn Benckert View Post
    Thank you. I was told by red or maybe I misunderstood them, but when I shoot at lower resolutions I am cropping the sensor or utilizing a small area of the sensor and that is why I maybe seeing noise in the footage. The noise would be worse the lower the resolution. So you're saying that is not correct?
    Dec 2014
    Quote Originally Posted by Michael Lindsay View Post
    (we passed on helium as we felt it too niche but the Gemini seems like a much more generally useful tool)
    I think I am going to go the Gemini route. I heard there might be an upgrade path for Epic owners to the Gemini.
    London UK
    Quote Originally Posted by adam brennan View Post
    Yes I believe there is... and I wouldn't hesitate for a second if I had a epic W. You will get more latitude, more sensitivity (but only when you need it) and a much better for slowmo camera. For general work, without specialist high res needs, it is very impressive!
    Senior Member Michael Hastings's Avatar
    Florida
    They are the same pixels so there wouldn't be more noise. The confusion may come from the fact that if you shoot higher resolution, then scale down to a lower resolution you are also scaling down the relative size of the noise so it is less apparent. That is true whether you are starting with an 8k, 6k, 5k, etc. camera. The advantage starting at 8K you have more room to scale to any other given resolution.
    Save the Sharks
    __________________
    RED Komodo soon. Original Manufacturer of RedOne & Epic/Scarlet/Weapon Underwater housings - contact us for sale or rent. RED owner since REDONE SN206. Manufacturer of Eye2Eye direct eye contact interviewing rig. 954.937.6600 (send a text first-having to use spam blocker these days) ... aquavideo1 at yahoo.com
    Jul 2010
    Stamford CT
    im not sure if that theory is right. ive shot a lot of MX and even dragon at low resolution an it looks terrible and very noisy...
    shooting full sensor and outputting prores isnt the same as cropping the sensor and outputting red. yes the the pixel density is the same, but when you crop a red your lenses go more telephoto because of the field of view has cropped in. so i belive the noise is larger in 1k ws or 2k cropped on a red vs shooting full frame and either in post or in camera getting a full frame output in an HD raster...
    that being said maybe im misreading you and you only meant the camera is down rezing it in real time like DSMC2 does? honestly i havent used DSMC2 so much so im new to all this in camera prores stuff somewhat. i have two arris at home and mostly rely on them and break my back lately since i rent my reds out
    I should clarify what i think is proper workflow is shooting reds at high resolution raw either with or without prores files. this preserves masters in quality. an epic w in 4k mode raw only has cropped a lot and isnt s35. 8k is nice and future proof but the 5k gemini is a better day to day for my needs as well. i want one but dont own it yet... i hope to get one though soon
    DIT, Assistant Editor, Phantom Tech, offering workflow services from acquisition to post
    Available with or without following gear:
    2 Alexa Studios
    2 Gemini packages
    Arri Amira Premium/UHD
    Alexa Mini with raw, 4/3
    Oconnor 2060
    A51 with RTX2080, Avid MC8, Premiere, and Resolve in the NYC/CT area.
    https://vestadalux.com
    Florida
    Not sure if you were referencing my post but I was primarily talking about shooting 8K raw and down rezzing in post rather than the in camera down rez to prores although it should work to some extent with the prores as well.
    Also shooting cropped modes doesn't change your lens or the light hitting the pixel - it just means you are ignoring pixels outside the cropped area. Your lens doesn't get more telephoto - you are just not using the whole image you created with it.
    Save the Sharks
    __________________
    Feb 2012
    Los Angeles, CA
    After now using both the Helium & Gemini, I prefer the Gemini.
    High ISO option, larger pixels, pleasing skin tones & no sensor cropping when shooting 96fps.
    The final feature which made me pull the trigger on the Gemini was the sensor height - almost no FOV loss when shooting with anamorphic lenses compared to the Alexa Mini.
    It's a great camera overall....
