Thread: Shutting down
Results 1 to 4 of 4
  1. #1 Shutting down
    Nov 2007
    Leksand, Sweden
    I get the message "The camera was improperly shut down" after having pressed the power button on the Ravenīs right side.
    Why is that?
    Doesn't seem to give any problems, but still ...
    Sverker Hahn
    Slower is better!
    Red Raven #002638
    Sigma 18-35 mm
    Canon 100-400 mm
    MacMini
    MacBook Pro
    Aug 2017
    CA
    You might be holding the Power/Record button down for too long.
    To power it off, press and hold for 2 seconds. If you hold longer, it's the equivalent of "pulling the plug" which isn't ideal especially as the camera goes through its shutdown commands.
    If you create a Support Ticket and send a Log file, RED Support could probably tell you exactly what is happening.
    Edit: I should note - 20+ seconds is a hard reset which will bring back the settings to default.
    Mar 2011
    Toronto, ON Canada
    What Alex said. 2 second rule...
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    I always just shut down via the touch screen to avoid that situation entirely.
