Took us a couple release candidate builds with lots of ups and downs to get to this one but its finally here, thank you to everyone that hammered on this during the Alpha/Beta/RC versions.
https://www.red.com/downloads
SIGNIFICANT CHANGES SINCE PREVIOUS BUILD v7.0.4
* Added "X" DSMC2 BRAIN support
* Added Sensor Flip/Mirror Scan Direction for DSMC2 MONSTRO 8K VV
* Added User-Defined Voltage Alert
* Added focus peaking tool
* Added ability to import CDLs, RMDs, and LUTs
* Added 5K 4:3 and 5K 4:3 2x ANA support to EPIC-W 8K S35, DSMC2 8K S35 and DSMC2 8K VV
* Added option to select a center mark dot (small/medium + color)
* Added Hybrid Log-Gamma display preset
* Added Avid DNxHD/HR HQ codec recording standalone option (RED RAVEN)
* Added Avid DNxHD/HR SQ codec recording standalone option (RED RAVEN)
* Added R3D + DNxHD/HR HQ codec recording option (RED RAVEN)
* Added R3D + DNxHD/HR SQ codec recording option (RED RAVEN)
* Added 30.00 fps project time base
* Added Kippertie ND Lens Mount (KipperTie Revolva) support
* Added Zeiss XD Metadata Support: Implemented extended Cooke /i commands for lens shading and distortion for metadata captured from Zeiss lenses (included in R3D metadata)
* Added Teradek Bolt DSMC2 module support
* Added Sigma Art lens for Nikon support
* Added Sigma lens firmware v2.01 support
* Added Sigma 50-100mm F1.8 DC HSM Art Lens for Canon support
* Added Sigma 14-24mm f/2.8 DG HSM Art for Canon support
* Added Sigma 105mm f/1.4 DG HSM Art for Canon support
* Added Sigma 14mm f/1.8 DG HSM Art for Canon support
* Added Sigma 70mm f/2.8 DG Macro Art for Canon support
* Added AF-S Nikkor 70-200mm f/2.8G ED VR II support
* Improved UI responsiveness
* Improved pixel processing along high contrast edges
* Improved user error messages
* Fixed camera startup issues that occurred with some batteries
* Fixed hot pixels that appeared after using Auto Calibration
* Fixed vertical lines displayed when changing resolution, magnify or playback with a RED Touch 4.7" LCD
* Fixed DSMC2 Side Handle lock feature
* Fixed potential errors associated with R3D+ProRes
* Fixed camera freeze when Auto Focus 'fast' mode selected
* Fixed Camera Info displayed for Scarlet-W Monochrome
* Fixed DSMC2 Sidekick navigation using vertical spinner
* Fixed Gamma Space preset always defaulting to REDgamma 4
* Fixed incorrect upper status bar aperture values in Playback
* Fixed loss of SYNC OUT after toggling 'Reduced Judder Preview'
* Fixed monitor artifacts toggling HDRx in 6K 6:5 with Lookaround
* Fixed quick flash on LCD when double-tapping LCD to exit Clean mode
* Fixed camera freeze after loading 3D LUT files
* Fixed slate parameters in playback
* Fixed camera freeze using DSMC2 Side Handle to focus
* Fixed SYNC failure after 'Genlock' selected with genlock device connected on startup
* Fixed test audio tone when camera is genlocked
* Fixed tethered REDMOTE detection of lost connection
* Fixed timecode overlay in playback after pressing REC button twice
* Fixed read out-of-focus peaking high contrast edge
* Fixed shutter angle spinner when setting above 90 degrees
* Fixed calibration export for EPIC-W GEMINI 5K S35
* Fixed camera crashing after selecting "Unknown" from search results
* Fixed incorrect f-stop limit displayed for some lenses
* Fixed histogram to display full range in ACES mode
* Fixed Genlock Offset text box to display all characters
* Fixed ISO in RAW mode for GEMINI sensor
* Fixed Yellow Cal indicator in Auto Cal mode
* Fixed split screen on Magnify with 4K FF and Lookaround enabled
* Fixed camera freeze attaching a lens during record
* Fixed intermittent LAN connection on startup
* Fixed focus control using DSMC2 Side Handle
* Fixed 'Confirm' style dropdown list in Focus > Mode dialog
* Fixed aperture lockout using a variable aperture zoom lens
* Fixed playback video corruption with 8K 6:5 ANA clip
* Fixed shortcut name of _0 when Settings > Attached Modules is mapped
* Fixed Gamma Space preset defaulting to REDgamma4
* Fixed GEMINI corrupted image in 4.5K 4:1/8:1 with Lookaround enabled
* Fixed inconsistent lens hot swap detection
* Fixed blank screen for extended period when loading a large clip in Playback
* Fixed intermittent diagonal tear on RED Touch 4.7" and RED Touch 7" LCD
* Fixed incorrect overlay mode after selecting clean mode and restarting camera
* Fixed intermittent RAVEN camera freeze with auto calibration
* Fixed overlay shift on RED Touch 9" LCD
* Fixed scrolling video on LCD in 5K FF and Framed Overlay enabled
* Fixed flashing pixels in sensor flip mode
* Fixed Infrastructure Mode SSID Scan button in Playback
* Fixed camera shutdown entering playback of 2K 2:1 Apple ProRes clip
* Fixed invalid 'Image Stabilization Not Supported' notification
* Fixed camera freeze loading large ProRes clip in Playback
* Fixed 'Unknown Unknown' resolution displayed in Playback with no media
* Fixed Frame Guide displayed on HDMI monitor with 'Auto Hide Menus' enabled
* Fixed artifacts displayed on the monitor in Playback when switching between clips
* Fixed colored bands displayed on the monitor in 2K FF, 1.3x, ProRes 4444 at 60 fps
* Fixed image roll on specific camera formats with 'Framed Overlay' enabled
* Fixed scrolling image in Magnify with 2K 6:5 2x format
* Fixed frame rate changing when entering Magnify
* Fixed SDI video scrolling at 60Hz with 'Framed Overlay' enabled
* Fixed camera shutdown after upgrade with auto calibration enabled
* Fixed display preset in Legacy mode with False Color enabled
* Fixed Exposure Tool in Legacy mode
* Fixed invalid Time Indicator with fully charged battery
* Fixed N/A Power Indicator with non-RED battery when set to Time Remaining
* Changed IPP2 to be the default image pipeline (Output Tone Map: Low, Highlight Roll-off: Soft)
* Removed Avid DNxHR LB codec
OPERATIONAL NOTES SPECIFIC TO BUILD v7.1.0.1
* Perform sensor calibration after upgrade.
* Refer to https://support.red.com/hc/en-us/sections/204939547 for the list of Known Issues
* Secure Format media before using Pre-Record.
* The horizon feature requires Gyro calibration be completed prior to use.
* Do not 3D sync when GEN ICON is not illuminated or yellow.
* Image Magnify is available during preview only.
* HD-SDI is True Progressive and does not support 1080i or 1080 PsF signal formats.
