Click here to go to the first RED TEAM post in this thread.   Thread: Announcing the RED DSMC2 PRODUCTION MODULE
Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 96
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 Announcing the RED DSMC2 PRODUCTION MODULE
    Fire Chief Jarred Land's Avatar
    https://www.red.com/DSMC2-Production-Module-V-Lock
    $4750
    CONNECTORS
    2x 3G-SDI outputs (75 Ω BNC), 60 Hz max frame rate
    Monitor output (75 Ω BNC), 60 Hz max frame rate
    2x 24V Aux Power / Remote Start/Stop Outputs (3-Pin Fischer), 2.5A Shared
    Aux Power Output (2-Pin 0B LEMO), 3.0A
    Aux Power Output (2-Pin P-Tap), 3.0A
    DC IN (6-Pin 1B LEMO socket)
    2x Balanced Audio inputs (3-Pin, full size XLR female)
    Stereo Headphone output (3.5 mm jack)
    Timecode input/output (5-Pin 0B LEMO)
    Genlock input (75 Ω BNC)
    Gigabit Ethernet input/output (9-Pin 0B LEMO)
    CTRL (Tally OUT / RS-232 Rx and Tx) (4-Pin 00 LEMO)
    USB Power output (Type A socket), 1.5A
    AUTO BOOT ON POWER
    2-position slider switch
    AUDIO
    2 channel, uncompressed, 24-bit, 48 KHz
    Input Formats: Balanced Line, Balanced Mic (w/o Phantom Power), Balanced Mic (w/ 48 V Phantom Power)
    Shipping mid-January. AB version in the works for later in 2019.
    Also available in a bundle with a new top handle and top plate.
    https://www.red.com/DSMC2-Production-Kit-V-Lock
    Senior Member Spencer Weaver's Avatar
    Sep 2015
    Wisconsin
    very cool!
    Your friendly Neighborhood REDuser
    Scarlet-W# 77
    http://spencerweaver.com/
  3.   Click here to go to the next RED TEAM post in this thread.
  #3
    REDUSER.NET Brent Carter's Avatar
    Aug 2007
    Irvine CA
    Quote Originally Posted by Spencer Weaver View Post
    Curious though... you state the price here is $3750. I love that price. The website price says "$4,750.00" though.
    Because I fatfingered the price when I sent it to Jarred, my bad.... True price is the $4750.
    Senior Member John Marchant's Avatar
    May 2010
    Normandy, England
    Is the monitor SDI a whole new feed, or does it borrow from the HDMI?
    I'd want to be able to run the EVF and LCD on the body, and still get two further independent outputs at the back.
    KipperTie - Authorised RED Rental, Pinewood Studios, UK
    Ready to hire: Monstro 8K VV | Helium 8K | Helium Monochrome 8K
    Check out our showreel , our OLPF products, or talk to us @kippertieltd
    Sep 2015
    Wisconsin
    Quote Originally Posted by Brent@RED View Post
    Ha ha, You owe me one Brent! You know Jarrad always outweighs whatever the website says! ;)
    Oh, and it's probably too late with wherever you're at with production, but it sure would be awesome if the unit has just even a few strategically placed 1/4-20 taps on the top for adding accessories or top plates. Is there must be a reason it doesn't have them?
    I suppose that's where we'll all be putting a velcro landing strip otherwise...
    Scarlet-W# 77
    Senior Member Ketch Rossi's Avatar
    Jan 2007
    USA | ITALY
    Awesome one!!
    Writer | Producer | Director | DP
    Ocean C o n s e r v a t i o n i s t
    _______________________________
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    Aug 2007
    Irvine CA
    Quote Originally Posted by John Marchant View Post
    The MON-1 port provides an additional monitor feed that is separate from the SDI-1 and SDI-2 cloned feeds. The secondary LCD/EVF port and an HDMI/MON-1 port cannot be used at the same time.
    Planned. If you force a hard mating between a brain and a module, the tolerances can stack up where it messes with the connection between the two. You should only ever connect a module to a brain via the screws through the module, not a bridge across the top.
    We took away that temptation : )
  #8
    Because adding 1/4-20s to the top of the module can pull apart the module connector from the brain if you put too much weight on it.
    Jan 2007
    USA | ITALY
    Oh, wait...
    Only V-Lock version? No 3-Stud one?
    Edit, never mind, coming in 2019 :)
    You guys ROCK!!!!
    Sep 2015
    Wisconsin
    Copy that. Interesting.
    Scarlet-W# 77
