Thread: Helium 8K vs. Helium 8K EPIC-W
Results 1 to 7 of 7
  1. #1 Helium 8K vs. Helium 8K EPIC-W
    Before RED changed their lineup to just be called DSMC2, they had an Helium 8K brain that said Epic-W on it. Here's the current Helium. The brains look physically identical to me and both have Helium Sensors. Does anyone know what the difference is if any with the two brains?
    If anyone else is curious, this is from Riley at RED:
    The main difference between the two cameras is the upgraded internals that come on the DSMC2 HELIUM. The EPIC-W can only do 8K at 30fps whereas the new DSMC2 HELIUM can do 8K at 60fps.
    The DSMC2 HELIUM also comes with a 2 year standard warranty, as opposed to the 1 year that comes with the EPIC-W.
    Senior Member Michael Hastings's Avatar
    Florida
    Quote Originally Posted by Dana Neibert View Post
    What he said.
    Should also be noted that up to 6K all of the frame rates available are the same for both Epic-
    W and DSMC Helium 8K.
    Image should be the same for both.
    Save the Sharks
    __________________
    RED Helium 8KS35 (For Rent) Original Manufacturer of Redone & Epic/Scarlet/Weapon Underwater housings - contact us for sale or rent. Manufacturer of Eye2Eye direct eye contact interviewing rig. 954.937.6600 www.Aquavideo.com ... aquavideo1 at yahoo.com
    Dec 2017
    When I asked RED about the $5,000 upgrade from Epic-W to Helium, they said basically some of the internal hardware was upgraded to manage the 60 fps at 8k and they changed the name plate too.
    Dec 2017
    When I asked RED about the $5,000 upgrade from Epic-W to Helium, they said basically some of the internal hardware was upgraded to manage the 60 fps at 8k and they changed the name plate too. No change to the sensor or body.
    Donīt forget that you get a new sideplate without the Epic-W written on it.
    UNDERSTATEMENT is the magic word here.
    Feels like a totally new camera. Like Leica did it on the brand new Q-P.
    By using the same exact same internals as the Q but removing the red dot on the body they created a beauty of a super great new camera :D
    Jokes aside, I did the upgrade to my epic-w after shooting with the Weapon Helium once.
    8k 60 and 75fps is key for me and really makes a big difference. Grabbing stills out of footage shot at 1/120 is so much better than with 1/60.
    Also beeing able to reframe 75fps for 4k delivery is a feature I use really often. 8k is now much more usable for me than it was on the Epic-W.
    Before I shot more 6k crop which is fine but I missed the s35 look and also wanted to use the full 8k for grabbing stills.
    If you donīt need that donīt upgrade.
    All we need is magination, a brain, a lens & a minimag
    "ERIKA" RED HELIUM DSMC2 #0008325
    PORTFILIO | ECN STUDIOS
    Senior Member Mark K.'s Avatar
    Melbourne, Australia
    Quote Originally Posted by Alexander_Klose View Post
    All good points, however the 6k crop is actually closer to regular S35mm than the full 8k sensor width is though.
    Unfortunately you're losing 25% of your sensor width, but having to drop to just a fraction (about 1mm) below standard S35mm width isn't a particularly horrific price to pay (in the scheme of things).
