Thread: What is "RED EXPRESS"?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 What is "RED EXPRESS"?
    Senior Member Peter Majtan's Avatar
    Feb 2008
    Japan, USA
    Any idea what is "RED EXPRESS"?
    It says in the specs that it will play "4K, 2K, 1080P, 720P AND SD FROM RED DISC AND RED EXPRESS"...
    Any ideas?
    You don't need eyes to see, You need a vision!
    www.petermajtan.com
    Senior Member Joseph Hutson's Avatar
    Jan 2008
    Dubai/USA/Anywhere at a Moment's Notice
    Quote Originally Posted by Peter Majtan View Post
    Any ideas?
    Media? :bleh:
    CINEPHOTOGRAPHER | Dubai
    TWITTER | @Hutson
    The answer is "No" 100% of the time you don't ask.
    Feb 2008
    Japan, USA
    D'oh! But what kind? It's not the external Red Drive, nor the CF and we can safely assume the the RED name of the optical DVD is the "Red Disc"...
    So what is "Red Express"?
    www.petermajtan.com
    Putting two and two together (and speculating wildly) it would sound as if it might be RED's answer to Sony's SxS - a high-efficiency ExpressCard solidstate memory card.
    Dylan Reeve
    Edit Geek
    Jan 2008
    I knew I would get this response, so that's why I wrote it.
    This has been posted on Red's website for quite a while though.
    I first checked USPTO.GOV and couldn't find a trademark registered, so I am not sure what the deal is...wanna register a trademark and sell it? :greedy: I wouldn't either.
    I am guessing that they have changed to a different name, or dropped it altogether. ???
    TWITTER | @Hutson
    Feb 2008
    Japan, USA
    Quote Originally Posted by Sycophant View Post
    This would actually make sense for both Epic & Scarlet as well, You might be onto something... Just pull it out of the camera and stick it to the slot in the side of Your Macbook Pro - or in the Red-Ray - and off You go watching Your footage... Hmmmmmmm..... :whistling:
    www.petermajtan.com
    Senior Member Harrison Diamond's Avatar
    Gainesville, Fla.
    Just a question, but are there any ExpressCard plugins available for desktop computers? I haven't seen anything like that yet. I know it is based on PCI Express, but i've never seen an interface for it on anything but a laptop.
    Harrison Diamond | Commercial Director - Sports Photographer - Aspiring Cinematographer
    Scarlet-X #1077
    There are plenty of options, but the biggest problem in a desktop computer is that they are usually implemented as a PCIexpress expansion card, which means the slot is on the back.
    Like this for example: http://www.amtron.com/reader/pcie101.htm
    There are also a few USB express card readers, but beware, they are not what they seem - they only implement the USB interface (ExpressCard has two interface options, USB and PCIe - either one or both can be used by a card). It will only support USB cards, and will obviously be limited to USB speeds. These are no good for SxS for example.
    There are also some front-mounting PCIe Express Card interfaces - like this one: http://www.synchrotech.com/products-...-drive_03.html
    There are a variety of OS/BIOS issues with PCIe hotswap too. Some adapters will only work if there is an express card mounted when the computer boots. In other cases the OS won't recognise or support the PCIe hotswap feature required to support the swapping cards. Be very careful to check all that out before you buy.
    As for the current batch of ExpressCard SSD devices - they are all (I think) crap. They implement only the USB interface - making them essentially hard-to-use USB memory sticks. SxS is different, but is a proprietary interface.
    Dylan Reeve
    Edit Geek
    Feb 2008
    Japan, USA
    Maybe Red will implement the PCIe properly with native support (at full speed) in laptops and external reader for desktops - even if it was FW800 (with future upgrade to FW3200 via firmware) - that would be enough to be practical... :)
    www.petermajtan.com
    What a good bit of insight. This has to be the case. At the moment RED are pushing CF to the limit, surely with express cards (SXS) they will have more bandwidth headroom.
    Adam Levins
    Scarlet-x Package
    Leica R 24mm 35mm 50mm 60mm Macro 90mm
    Grip and HMI Lighting kit
    www.levinspictures.com
