Thread: Gemini Noise Issue
Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 60
  1. #1 Gemini Noise Issue
    Hi everyone.
    I'm a new user of RED and I shoot a commercial for the first time with my new Gemini ! I did a lot of testing before going out for this shoot, especially in low light condition. I saw a bit of noise before, but nothing embarrassing regarding the shooting conditions.
    The problem is that I have noise on a particular shot, and I am very surprised, since the conditions were perfect ! Can you tell me if it's normal ? (see the attachment grab)
    https://drive.google.com/drive/folde...CR?usp=sharing
    Here are my setting and configuration ;
    Manual Black Shading (for every of the exposure time I usually use on set) : 22 feb 2019
    Temp : 39C (adaptative)
    On Set :
    800 ISO - 1/50 - 25 FPS - 5K WS
    Zeiss Contax 21mm (open at f4)
    RAW Level Bar : at 0 on both side
    T/E : Green
    Camera temp : 39C (the camera was ON since 30min at least)
    Color management : IPP2 - RWG - Log3G10
    Lut on set : CL Canes (from lutify.me)
    Matte Box : Schneider filter Hollywood Black Magic 1
    Set effect : Smoke
    Thank you everyone.
    (Sorry, my English is a little bit rusty)
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by Julien Jauffret View Post
    Hi everyone.
    On Set :
    T/E : Green
    Set effect : Smoke
    Thank you everyone.
    Link not work, you share permission to pubblic .
    Grading Suite Davinci Resolve, Rental RED Digital camera.
    MONSTRO 8k CF #831 "BLACK PEARL" , EPIC-W GEMINI # "DAFNE".
    ARRI ALEXA EV , ALEXA MINI LF "ROZI"
    SITE
    www.cine5k.ch
    Hi
    I’ve just sent you the access
    Oct 2009
    Switzerland- LUGANO
    Everything good. Not problems, little bit noise in dark zone...
    You did everything correctly. And also be a beautiful image.
    In fact, technically, you're underexposed, if you look at the histogram, by + -1 stop.
    Perhaps in this case you could have used the low light mode to remove a bit of noise .
    The advice I can give you, do not focus on the single frame, otherwise "go crazy" to look for noise in every corner of the image.
    *Export it and watch it on the move. I think you'll be happier;)
    SITE
    www.cine5k.ch
    Thank you very much for your advices Luigi, It reassures me
    Aug 2011
    Julien,
    I'm probably in the minority here but I say add a little contrast and color back. I don't know if you were going for a "hazy Glow" or if you wanted to lift the shadows in this scene. I think you can still have some more contrast and color and still keep that slight glow-diffused look.
    I tried to reduce the noise in this scene , but it never looked as good as the sort of fine grain noise that's already in this footage. This is only a suggestion and I'm probably completely off track from the look you were "actually" going for but I thought I would put my 2 cents in.
    Rand,
    Thanks for your advice. For now, it was just a technical question about noise, but you are right about the color and contrast ,I will work this at the time of color grading !
    Senior Member Tommaso Alvisi's Avatar
    Jan 2009
    ITALY
    Julien, which OLPF did you use?
    TOMMASO ALVISI | tommasoalvisi.com
    Weapon 6K Carbon Fiber #1605 aka qp
    instagram | twitter
    Hi Tommaso,
    I use the standard
    Jan 2009
    ITALY
    mmm strange...noise seems a little bit excessive @ 800 with the STD OLPF...especially chroma noise
    instagram | twitter
Tags for this Thread
View Tag Cloud
