Thread: Gemini Noise Issue
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 60
  1. #11
    That's exactly what annoys me in the first place
    What was the compression ratio ?
    Analog > Apollo wooden handgrip http://omeneo.com
    Digital > Primers - professional image transformation tools http://omeneo.com/primers
    imdb
    "Como delfines en el fondo del oceano
    volamos por el universo incentivados por la esperanza"
    "L'esperanza", Sven Väth
    "It's a poor sort of memory that only works backwards"
    Jung/ Carol
    Senior Member Tommaso Alvisi's Avatar
    Jan 2009
    ITALY
    8:1
    TOMMASO ALVISI | tommasoalvisi.com
    Weapon 6K Carbon Fiber #1605 aka qp
    instagram | twitter
    Well there you go.
    You are not looking at only noise. You are looking at a texture from smoke + diffusion + noise + wavelets dealing with low level signal.
    Fine texture costs MB/s.
    imdb
    Jung/ Carol
    It make sens, I’ll try a higher compression next time I go with a smoky/haze effect.
    Thank you Hrvoje
    Jan 2012
    Brooklyn, NY
    Here's one at 6:1 with no haze. Also has lots of noise. Thoughts?
    https://drive.google.com/file/d/1Koz...ew?usp=sharing
    Quote Originally Posted by Julien Jauffret View Post
    Thank you Hrvoje
    You're welcome...
    Lower compression. :)
    I propose 2:1 on Gemini for shots like these.
    imdb
    Jung/ Carol
    Quote Originally Posted by Kyle Kelley View Post
    Light quality + underexposure + compression + WB channel push
    When you are not shooting daylight WB light source and not compensating that with the optical filter temperature correction, don't count on the same noise levels.
    imdb
    Jung/ Carol
    Aug 2011
    Kyle,
    As suggest above, maybe lower compression and more light. I graded it a little, but with noise reduction it looked muddy and without noise reduction, I don't think that you would want to use this file. I think if you maybe provided a very short clip, Both a Temporal and Spatial noise reduction could be applied to maybe get better results, or maybe not. It's hard to judge the usability of a noisy file with only 1 frame.
    Warmer version out of Redcine-X Pro with no noise reduction in resolve.
    Jan 2012
    Brooklyn, NY
    Interesting. Thanks, Rand. As a rule I generally stay at 800 ISO or lower, but did this little short film and pushed it a lot. The above still was at 2500, and based on the Gemini's LL 3200 rating, I thought I'd be okay. Happy to provide a short clip if you want to play around.
Tags for this Thread
View Tag Cloud
