Thread: Pro Res and Fat 32.....Help!
Results 1 to 5 of 5
  1. #1 Pro Res and Fat 32.....Help!
    Senior Member steve green's Avatar
    Jan 2012
    Thousand Oaks, Ca
    Oh man, did I mess things up!
    I shot a small doc piece that is for projection at a corporate show. The format needed for the screen is 3840x1280 (3:1). The client didn't need or want the R3D files so I figured, just shoot Pro Res at 4K. I knew about formatting for UDF as oppose to FAT 32, and I thought I had made the change in the menu, but obviously I didn't!
    My client did the downloads (no spot checking of the footage) and ran for a plane. Everything was good until tonight I was going through some clips off the mags and realized that there's a new .MOV every 4.17 GB (about 30 seconds). We did two 45 minutes interviews and a couple more 10-15 minute takes with dialogue. I don't know what they edit on, I'm assuming Final Cut only because I've never heard them mention DNX in the past.
    Is there any time efficient way to link all these .MOV's or are we just screwed?
    Senior Member Blair Thornton's Avatar
    Oct 2013
    Toronto
    foolclip - spanned DSMC2 PRORES clips join tool.
    http://www.reduser.net/forum/showthr...ard-workaround
    Apr 2016
    Washington, DC
    Could you also just have them drop all the clips for each interview/take into a final cut timeline and have them create single compound clips?
    https://support.apple.com/kb/PH12631?locale=en_US
    Jan 2012
    Thousand Oaks, Ca
    Quote Originally Posted by Blair Thornton View Post
    Blair,
    This is brilliant! I tried it myself, and I have no edit skills whatsoever, and it worked perfect! Thank you!
    Steve
    Jan 2012
    Thousand Oaks, Ca
    Quote Originally Posted by Travis Edwards View Post
    Travis,
    I'll forward this Final Cut option to them as well, just in case. Thanks for that!
