Thread: FCPX TO REDCINE X
Results 1 to 8 of 8
  1. #1 FCPX TO REDCINE X
    Senior Member Jacobo Martinez's Avatar
    Jul 2013
    Nicaragua
    Hi, I want to export my edit from FCPX to REDCINE x vía XML or edl but FCPX only allows the FCPX XML, how to you guys conform? Thanks
    Jul 2013
    Nicaragua
    No one in reduser use FCP X?
    Aug 2017
    CA
    Did you try opening the XML in REDCINE-X Pro? Should work. I would recommend trying XML version 1.7 if you have issues with the original one.
    Jul 2013
    Nicaragua
    Quote Originally Posted by Alex.E View Post
    Thanks Alex but I redcinex cannot open fcpxml files.
    Redcine does not really do XMLs or edls so well. Why do you want to go there from FCPX?
    One work around, download a free copy of resolve. Import the XML there, Export as a simple EDL or any other format that RCXP want to chew on.
    But as I remember from last time using RCXP for such task it does not really do retimes correctly and such so its not the best of conforming tool.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
    Jul 2013
    Nicaragua
    Thanks Bjorn your awesome. I will try the resolve workaround. I never had good experience with premiere to rcx, it always added one extra frame to each clip.
    Aug 2017
    CA
    Quote Originally Posted by Jacobo Martinez View Post
    I just got home and ran a test. I am able to import fcpxml 1.7 from Final Cut Pro X 10.4.5 into REDCINE-X Pro 50.1 Release Candidate.
    My original theory is correct that xml 1.8 is not supported.
    Also tested with 50.5 and 50.4.
    Is there something specific you are looking for when you import or are you having trouble getting the files in?
    Junior Member
    Jul 2014
    Vancouver, BC
    Some of us do ;)
    Rami Mikhail - Director @ Rami Films
