Thread: 8k r3d 5:1- 6 STOP UNDER AND OVER EXPOSE TEST
Page 6 of 6 FirstFirst ... 23456
Results 51 to 58 of 58
  1. #51
    Dec 2014
    Sarajevo
    Quote Originally Posted by Hrvoje Simic View Post
    When transformed to 709 you are looking at properties of transformation too. :)
    Dammit...
    Senior Member Aris_Gavriilidis's Avatar
    Feb 2015
    Athens, Greece
    [QUOTE=Mark Wuerthner;1860343]
    Quote Originally Posted by Aris_Gavriilidis View Post
    Yup, sure thing, here's a test Geoff Boyle performed, pause at the 1st second and see for yourself, (Venice at T2-2.8), the Venice maintains color and separation at the High Saturation Color Reference Chart's second to last row, whereas both Alexa Mini and Monstro are barely holding on. Also note how the Monstro is actually exposed at T4-5.6 and it's still a bit behind. Small difference but it's there. I think that's pretty remarkable performance on Sony's end.
    https://vimeo.com/283339506
    You might want to look at this test as it shows something quite different:
    https://vimeo.com/showcase/5957128/video/333200960
    Seen this test as well, indeed very different to Boyle's. It's odd how the Alexa is outperforming the Venice here, though on the other hand the Monstro is still marginally behind in highlight retention but absolutely destroys the Venice in the shadows, so this test is similar to Boyle's results in that regard and additionally, in a way, it's another confirmation of the need to rate this beast higher than 800.
    EPIC - X DRAGON #8215 "Allie"
    Seen this test as well, indeed very different to Boyle's. It's odd .
    Oddness remover tool just above.
    http://i68.tinypic.com/drcb4y.jpg
    Analog > Camera feel optimization http://omeneo.com
    Digital > Camera performance optimization http://omeneo.com/primers
    imdb
    "Como delfines en el fondo del oceano
    volamos por el universo incentivados por la esperanza"
    "L'esperanza", Sven Väth
    "It's a poor sort of memory that only works backwards"
    Jung/ Carol
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    Seen this test as well, indeed very different to Boyle's. It's odd...
    One test lit for each camera's native sensitivity and the other lit for the same level across all cameras. ISO 500 on Venice means on Boyle's test, it's being underexposed 2/3 from it's native compared to Alexa, so it's getting some help there.
    Junior Member
    Oct 2013
    Senior Member Curtis boggs's Avatar
    Jun 2016
    Virginia Beach, VA
    The iris over/under test is good at revealing what happens at the point of clipping and what happens deep in the noise floor.
    I just hope that people understand that with any digital system once you've hard clipped/over exposed into the heavens and hard crushed/under exposed into the noise floor there's nothing left to salvage.
    Honestly, worked the same way for film. There is a point where nothing exists.
    Never a more true statement, .. once it's gone, it's gone!
    Curtis Boggs
    www.cboggs.com
    Cinematographer-DP-Colorist
    Epic-W 8k - G&E
    Sigma Cinema prime set
    Leica-R Cine mod prime set
    Senior Member David J. Buchanan's Avatar
    Oct 2016
    Minnesota
    Quote Originally Posted by Goker Goren View Post
    DEB is almost useless on anything but Dragon.
    These old standards don't translate well to the new sensor(s).
    I still prefer legacy but that's only because they haven't came up with anything better in the color science area, esp since there are three new sensors since Dragon.
    BLACK - Now on Amazon!
    Corporate G&E Package
    Monstro, Zeiss Otus 28, 55, 85
    davidjbuchanan.com | wecofilms.com
    Quote Originally Posted by David J. Buchanan View Post
    DEB has now transformed into a new algorithm if you have opened RCX anytime recently called "Chromatic Noise Reduction". It's actually fairly different than DEB of yesteryear and is a proper CNR method now.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
