Thread: Panasonic LUMIX S1H Full Overview 6K Test Footage and System Review First Look
Page 12 of 35 FirstFirst ... 2891011121314151622 ... LastLast
Results 111 to 120 of 347
  1. #111
    Quote Originally Posted by rand thompson View Post
    Here's a Panasonic S1H ISO test from a 320-204800 range. I think maybe ISO 10000 would be the highest ISO I would use.
    Few remarks.
    1) Judging noise, texture and resolution (acuity) tests and image quality in general over web compression is misleading.
    In the contex of noise, this can mislead in two ways:
    a) appear superior than it actually is (when compression smoothens irritaing noise) and
    b) appear worse than it actually is ( when compression accentuates noise into more visible texture instability, like splotches or compression blocks) -
    while in reality it is much finer and less noticeable
    2) Digital "ISO" approach is best perceived seen through two priorities:
    A) Image quality
    B) Priority to get the shot at any cost
    If priority is image quality, "Thou shall not imagine sensitivity and stretch the bits". Forget the other numbers. Because no additional data is captured past the base analog gain. It is not just the noise levels. It is stretching of the captured bits to appear as something which was not captured, which significantly reduces image quality and significantly decreases the range of image manipulation in post.
    If priority is getting the shot (documentary, event coverage without any control of the lighting, one shot opportunity without any setup alternative etc.) and otherwise there is no shot, and footage won't see proper post... the route has a justification to differ.
    Surfing in the middle at a whim, just because it's there, treating post image push as a camera exposure control by shooting at digital equivalent of ISO which just "seems okay" due to "tolerable noise" at a glance, is just destroying the image in multiple parameters and all the resolution, image colour and depth performance advantages, as well as post production image shaping ability - fly out the window straight in a dumpster.
    So to put this in the context with S1H - The question whether this and this ISO is usable...needs a context "for what".
    Aug 2011
    Hrvoje,
    I think if a few Raw(H.264 clips out of camera) clips at maybe a few of the ISO's under or around the 10000 ISO range would have allowed for a better assessment of the actual "useable" noise range for "professional" standards. I know you had access to the camera, in your experience, what did you find to be a "useable" range for "professional" use in both controlled and uncontrolled lighting situations when image quality is the priority?
    There is no single, simple and generally applicable answer to that question.
    1) "Professional" covers a wide range, from TV and cinema to event coverage, documentary, corporate, wedding...etc. Priorities differ.
    2) ISO equivalent push results differ depending on
    a) light temperature and quality - determining colour channel balance and saturation proportionality
    b) scene light intensity and exposure levels - determining overall sensor saturation and what is being pushed
    c) recording quality - affecting bit depth, spatial resolution and tonal resolution which together determine image definiton
    With regards to a) and b) - with same ISO equivalent value:
    Bright scene shot under natural light will have one camera response.
    Dusk scene under natural light will have another.
    Night scene another.
    3200K controlled light well lit scene another.
    3200K lit dark scene another.
    Scene under street lights another.
    Scene under different street lights another.
    Scene under mixed light combo 1/2/3/etc another.
    Dark city street another.
    You get the picture.
    In the example of two diametrically opposed shooting scenarios - you cannot expect the same ISO performance in
    - a brighter scene under natural light where the image signal is well balanced and most of it is in mid and upper range
    and
    - a dark city street with channel starvation, colour spectrum circus and most burried below 30%.
    Not even close.
    S1H ISO4000 covers wide range of usages. There is some shadow detail softening but nothing major. Chroma noise is well controlled.
    From that point, increasing the digital image push, usability and results depend on everything mentioned previously and individual or production priorities and criteria.
    To have the best insight and avoid image quality problems, one should test the camera and results before the project in same shooting conditions the project will be shot in. When possible.
    Aug 2011
    Alright then understood and thanks for your very detailed answer.
    Senior Member Timur Civan's Avatar
    Jan 2007
    LA - NYC
    Quote Originally Posted by andrewhake View Post
    Have you tested with timecode input yet? Curious if the S1H can accept continuous timecode input from from an external timecode box rather than just be jam sync'd like the GH5S.
    Yes i just jammed it to the mixer once in the morning. I'm pretty sure it even held through battery changes. Jamming is so fast, I just did it every time we changed mags on the RED. We were shooting long interviews, the S1H Was BCam and Broll Camera.
    Director Of Photography
    RED Weapon Helium - Gemini
    --Official Sigma Pro--
    www.TimurCivan.com
    Timurcivan@gmail.com
    9175894424
    Aug 2011
    LUMIX S1H REVIEW IN THE LAND OF DRAGONS | Real World Review & Video Field Test
    Rowe Films
    https://www.youtube.com/watch?v=RC5lfFLyWUk
    Jan 2014
    Europe
    S1H with CANON Sumire lenses. I recommend turning the sound off :-)
    https://vimeo.com/379469453?fbclid=I...OMHzVeuo1j97ps
    Aug 2011
    S1H: What no one is talking about!
    By THE DP JOURNEY
    https://www.youtube.com/watch?v=FQeZsBwzr0Q
    Aug 2011
    Walking Around New Orleans - Filmed on the Panasonic Lumix S1H
    Chris Truitt
    https://www.youtube.com/watch?v=NTl5oikAUKQ
    Aug 2011
    Lumix S1H Footage Hamburg
    By Brinkmann Werbung
    https://vimeo.com/373433197
