Thread: Applying heatsink to Radian TX and RX to help with heating?
Results 1 to 7 of 7
  1. #1 Applying heatsink to Radian TX and RX to help with heating?
    Feb 2013
    Toronto, Canada
    I have old radian TX and RX and they get fairly hot on set. Would applying these help at all? https://www.amazon.ca/Heatsink-14x14...ateway&sr=8-14
    These are the radians: https://www.bhphotovideo.com/c/produ..._wireless.html
    I'd like to make them last as long as possible. Any other suggestions on what to do about the heating?
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    If you're going to cool the casing, then you want to make sure that as much heat transfer from the chips to the case happens. So I would also open them up and make sure there's some thermal pads in place so that the chips transfer a good amount of heat to the case.
    Senior Member Tommaso Alvisi's Avatar
    Jan 2009
    ITALY
    Case is made in plastic...
    I think the best approach is let these alone and let the holes on the sides to exhaust the internal heat (by design)
    TOMMASO ALVISI | tommasoalvisi.com
    Weapon 6K Carbon Fiber #1605 aka qp
    instagram | twitter
    Oct 2013
    Tucson, AZ
    Quote Originally Posted by Tommaso Alvisi View Post
    Oh yikes, yeah didn't know these were plastic.
    Feb 2013
    Toronto, Canada
    Sorry I didn't understand your suggestion
    Oct 2013
    Tucson, AZ
    Quote Originally Posted by yves d View Post
    He's saying leave it be.
    Jan 2009
    ITALY
    Yep, the holes are for creating a suction based on the difference in density of the air once heated, it's this way by design.
    The only better way to tackle this would be rehousing the units in aluminium cases with big integrated heatsinks which would provide better passive heat dissipation but the value of these tx/rx make this approach overkill imho...
    In the past I used Paralinx Arrow systems (same thing) for years without issues...these were indeed very hot too but probably within the thermal design limits of the Amimon chips inside.
    instagram | twitter
