Thread: Letus Anamorphx Adapters on Monstro?
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Aug 2007
    Macau
    Quote Originally Posted by Bob Gundu View Post
    Woah Bob that looks stunning!
    Sérgio Perez
    Weapon Monstro #03294 "Amochai" in Macau
    Video Director/Creative/Producer
    http://vimeo.com/user1503556
    https://www.youtube.com/user/spzprod..._as=subscriber
    Aug 2007
    Macau
    Quote Originally Posted by Josiah Duncan View Post
    Also to note I tested these out with helium, and while it covered on the 55 and 85, the 28mm requires a slight crop to fully cover the 8K 4:3 S35 helium sensor size, so be prepared to crop in a bit on monstro
    Thanks for the feedback Josiah, was planning to use it with the Otus set, but seems like a 35 is the widest one can pull of on the Monstro with the Letus. Still gives a field of view of 19mm which is not bad.
    Bob, a 50 should be the widest one could go fr with the Avascope, this equals a 25mm, or a 28mm field of view? A bit limiting doesn’t it?
    Sérgio Perez
    Mar 2011
    Toronto, ON Canada
    Quote Originally Posted by Sergio Perez View Post
    Plenty wide for me. I also wanted something that was small, and sharp and sing focus. So I think Aviascope ideal.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Aug 2007
    Macau
    Fair enough, from your shots seems like it’s actually a handheld friendly solution? Josiah, can the Letus be handheldable for the type of shots Bob did? That extra width really would help in some of the stuff I shoot, heritage buildings, tourism related content...
    Sérgio Perez
    Aug 2007
    Macau
    Seems like we are back to the 35mm adapter days haha...
    Sérgio Perez
    Senior Member Bérenger Brillante's Avatar
    Dec 2007
    Paris, France
    With the Aivascope the picture quality and ease of use are not the same though.
    But there are rigs on facebook's Anamorphic shooters that are really really reminiscent of these days indeed.
    Bérenger B. Brillante
    --Director Showreel--
    Senior Member Zack Birlew's Avatar
    California and Las Vegas
    I've only fiddled with the Letus on the NAB show floor but it seemed like a good solution, nice and sharp with good flares. The squeeze ratio of 1.8x was odd though, why not push it for 2x? But if Josiah's tests prove to be accurate, they didn't even get the 1.8x right. Oh well, you would just do tests and figure out your framing in pre-production testing anyway. I have many anamorphic adapters and I planned on doing a big anamorphic video after completing my first feature film. For me, I'm really torn between the SLR Magic 2x and the Isco RED 2x projector anamorphic, both are great for anamorphic use but the SLR Magic edges towards being too modern for my tastes but is easy to use and the Isco has a clear and classic anamorphic look but the red version hardly flares at all. Much like the Letus, the SLR Magic is a more practical solution as it just screws on to the front of your lenses and the Letus is the easiest since it can go on rails. The best of both might be the newer SLR Magic 65 1.33x adapter but I haven't seen too much about it as of yet, although I wouldn't mind getting one to try myself.
    Now, the problems you'll have with adapters all come down to focus being compromised, light loss, the extra time spent changing a lens to use with the adapter, and the extra effort to make sure your alignment is correct. The Letus is easier as it's on rails so you won't have to worry about alignment but all the anamorphic adapters have a focusing mechanism to them, save for the older videocamera anamorphics like the Panasonic LA7200. Depending which anamorphic adapter you go with, you'll be better served by also purchasing a compatible single focus solution, like the SLR Magic Rangefinder. The Letus adapter and the SLR Magic 65 don't have single focus solutions so you'll have to do dual focus but you'll get more coverage and compatibility with certain larger lenses and focal lengths. Lastly, you'll also have to accept that you'll need more lighting and can't get away with fast F1.4 lenses as anamorphic adapters normally require F4 and greater to get acceptable images using them. I find F2.8 can be good for certain situations but it really depends on the taking lens so sticking to the F4 rule is ideal. For really wide angle stuff, you'll either have to rent appropriate wide angle anamorphic lenses, use Sigma ART or certain Zeiss lenses with the Vidatlantic Cinemorph mod, or take a look at using modified Russian lenses from Ironglass Adapters.
    Mar 2011
    Toronto, ON Canada
    Quote Originally Posted by Zack Birlew View Post
    Thats why the Aivascope is ideal. Single focus, no light loss, sharp, and rails if you want to.
    10 frame handles
    Vimeo
    Instagram
    Oct 2017
    Not one to say the whole "if you have the money for a Red, then buy pro accessories" as this has been directed at me, and I do not have the money, but "if you have the money for a Red, and are working with it, then why not just buy the Orions, or a single Orion. Or rent anamorphic cheaply (Cooke, Arri)." Adapters always seems to miss the mark.
    My question would be, anyone using the adapter, have you shot with the Cooke Anas?
    Dec 2010
    Toronto & Vancouver
    Cause renting can quickly cost as much as owning the adapter (which if you're an owner/op, can actually generate revenue for you across all your current and future cameras and most lenses).
    And Orions cost more than REDs... especially used REDs. For a 3 lens set (~$27500), you could get a Helium, Gemini, Dragon-X, or be in the used-Monstro ballpark.... For one Orion lens you could get an Epic-Dragon package, Scarlet-W pkg, Raven pkg, or Komodo. So saying 'just get real anamorphics' doesn't necessarily make financial sense.
    Conversely, a more cost effective strategy would be the reverse; buy a 3 lens set of Orions and rent whatever camera package is needed for whatever project comes up. That would actually be a cheaper rental cost, future proof, and open up your market to include any camera that can be adapted to PL!
