Click here to go to the first RED TEAM post in this thread.   Thread: DaVinci Resolve 16.2. -- With R3D Metal GPU acceleration ( Mac )
Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
  1. #21
    Oct 2008
    Baltimore, MD
    So while I think this is probably badass and much needed on lower core count systems, it kinda has the opposite effect for High core count systems.
    Example
    I have a Mac Pro 7,1, 16 core with Dual Radeon VII (aftermarket, not MPX).
    For 6K and under, it makes more sense for me to do CPU decode, and leave more GPU overhead for color transforms, blurs and NR. In 7K and 8K projects, it is pretty sweet to hit 24-40 FPS full debayer decode to 4K Prores. But it uses such a large amount of GPU resources, that with just a tetrahedral LUT transform and some basic corrections, I am already maxed out on GPU resources. Not enough overhead for full grades.
    Hopefully some further improvements and BIG Navi will make this a moot point. I Think Puget system already came to this conclusion with CUDA decode.
    I wish the switch from CPU to GPU decode did not require a restart of Resolve.
    Dec 2010
    Toronto & Vancouver
    Quote Originally Posted by Curtis boggs View Post
    will this work on Mojave or does it require Catalina?
    It runs on Mojave 14.6.
    Would being able to choose just decompression make sense for older systems? (On a 2gb NVIDIA 750m unfortunately Decompression & Debayer is slower than just Debayer, but maybe just decompression would run faster than just debayer?)
    Senior Member AndreasOberg's Avatar
    Oct 2011
    Fantastic!
    Did a performance test on Apple 16" to specked laptop and got almost identical results to running on CPU. Can run Quarter Debay but not half debayer. If I optimize media I get nearly on the second the same results as with CPU. However it seems to use slightly less power. I can also see that the CPU is almost not used at all so it is clearly putting most of the job on the GPU.
    Andreas
    www.ObergWildlife.com- Natural History Filmmaking
    www.WildlifeRescueMovie.com- Saving the animals of the Rainforest!
    2 x RED DSCM2 8K Helium, Phantom 4K VEO990, Movi Pro Gimbal, Inspire 2 X7, OConnor 2560, Canon 50-1000mm
    I'm not seeing anything exciting on my iMac Pro for DaVinci Resolve. I tested converting minute-long 8K video into ProRes H.264 and with just GPU Debayer (didn't get the Decode option in the DaVinci Resolve preferences), it took 3:14. With RR-X (either set to Decode or Decode and Debayer) it took just over a minute.
    Could it be that there are many places where preferences have to be set to get the correct behavior, not only in the main preference (which requires a Resolve restart)?
    I'd really like to be impressed enough to retire my 5 year old RR-X.
    "Dream so big you can share!"
    Oct 2008
    Baltimore, MD
    Michael
    All about work sharing, you are forcing the GPU to do both Debayer and H264 encode. With the RR-x, they are split up the task.
    Dec 2010
    Toronto & Vancouver
    Quote Originally Posted by Michael Tiemann View Post
    Make sure you have Metal selected in "Memory and GPU" of preferences. Then in Decode Options, have the "Use GPU for R3D" drop down menu on "Decompression and Debayer" (I think using the GPU just the debayer has been around since like ~2013.)
    I do have Metal for Memory and GPU preferences. In Decode Options, if I have Rocket enabled, the Use GPU for R3D gives no options. If I don't have RR-X enabled, the two options are "None" and "Debayer". I ran the test again, this time with ProRes LT as the target.
    GPU-only: 3:20
    RR-X decode only: 1:12
    RR-X is still better than anything Apple has to offer iMac Pro.
    Dec 2010
    Toronto & Vancouver
    GPU-only: 3:20
    OH, make sure you have Mojave 14.6 or newer and it's actually 16.2.1 (not 16.2 as the thread title suggests).
    If that's not it, I don't know what else... Maybe the RRX is overriding the options?
    Was excited about this, but having some major issues on a loaded 2017 iMac Pro. With 'Memory and GPU' set to Metal, and 'Decompression and Debayer' turned on in decode options, I get stuttery playback on 8k footage... at any playback resolution, even at quarter proxy mode. It says its playing back at 23.98 but in actuality it stutters every half second... visually it appears almost as if the hard drive were the bottleneck, like it can't pull frames quickly enough from it. But when I switch back to OpenCL and set decode to just Decompression, I get smooth realtime playback at half resolution, and even full resolution on more compressed 8k shots. Same shots play back great in Premiere at half resolution as well. Are there any settings I might be missing?
    Ben Sturgulewski
    www.sturgefilm.com
    Apr 2016
    Bend, Oregon
    I am experiencing the same as Ben, 5K Scarlet footage 10:1
    Same exact symptoms with Resolve telling me in the viewer that it was playing at constant 23.98, but stuttering every half second. Same problem with clips utilizing optimized media, which has in the past played back smoothly
    I, too, thought it might be my RAID array being wonky, but RED Player was able to play back the same clips, without stutter, and at higher resolution. Furthermore, clips copied to the internal SSD performed no better in Resolve
    Much better performance on my MacBook Pro (Mojave 10.14.6) once I switched back to OpenCL
