Thread: My RED rant for the night
Results 1 to 9 of 9
  1. #1 My RED rant for the night
    May 2019
    Bay Area
    So...Got home tonight after shooting a music video for a emerging pop artist and found some disappointing aspects of my RED ecosystem...
    Don't get my wrong.. Color science and all that jazz is awesome with my old school scarlet and epic-m. But tonight the DP asked for wide 16mm for a pool dive in shoot. I pulled the 18mm RPP and we noticed with 6k WS there was a slight vignette on the corners. WOW.. just didn't expect that out of a RED ecosystem line. Maybe its because these are older items but dang... Still love my RPP and zoom set. Just a lil bummed the RPP's don't cover the full s35 frame.
    Senior Member Scot Yount's Avatar
    Dec 2014
    Marblehead, Massachusetts
    Quote Originally Posted by Jamil Stubbs View Post
    6K WS is larger than super 35. I might be wrong here, but the lenses were developed during the 5k days which are s35. I have a Scarlet MX that I still use and to my knowledge, all the RED lenses that I have owned or still own cover the sensor.
    Forged CF Helium 8K 00107
    Storm Trooper Komodo 0149
    Scarlet X 02249 (The Gateway Drug)
    RED Pro Zooms
    Zeiss Otus
    Xeen CF
    Director/DP at https://www.butcherbox.com
    Living life by the ocean.
    Feb 2010
    Toronto
    The RPP lens set was designed for super35 - 6K Dragon DSMC1 is just larger than that.
    My 18mm RPP will cover 6K HD, but 6K and 6Kws are just outside that coverage at most focus and T-stops. My super early RED 18-50 zoom (pre the 'pro' model) will cover Dragon 6K an 6Kws - but I'm pretty sure the internals on that are from a stills zoom.
    C.S.C. Associate Member
    If I don't own it I rent it...
    Senior Member Brian F Kobylarz's Avatar
    Dec 2007
    Norwich, CT. USA
    The RED Pro Primes were introduced over ten years ago - sometime in 2009 as I recall.
    They were brought to the market to complement the RED One 4K sensor.
    At the time, quality PL glass was extremely expensive especially when compared to the price point for the RPP's.
    RED introduced affordable cinema optics just as they disrupted the camera market.
    While the wider lenses vignette at higher resolutions, I continue to use the set of RPP's I have had for over a decade.
    Same happens with many other wide PL lenses.
    No need to rant - just choose the lens you need to achieve the shot you are looking for.
    Mar 2018
    Quote Originally Posted by Brian F Kobylarz View Post
    They were rehoused Sigma lenses were they not?
    Quote Originally Posted by Tyler Besh View Post
    They are not. Unique Optics and RED Pro Primes share the same design, but some breach of contract by Unique went down.
    RPPs are/were designed for S35, only sticky bit along the way is RED eventually made larger than S35 sensors. Most of their S35 sensors are what I call S35+, but of course you can crop to the actual format size. For instance Dragon or Monstro at 5K or 5K HD is the width S35 and works fine.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Alex Lubensky's Avatar
    Nov 2016
    Kiev, Ukraine
    Nothing wrong here, at 6k its bigger than s35.
    Actually, those are not the only one lenses, which are going to vignette on wides. Say, wider Master Primes vignette on Gemini @5K.
    My own RPZ 18-85 zoom does cover 4K MX sensor, but at 5k 16x9 it vignettes slightly, and at 5k 17:9 DCI it does vignette up to 40mm.
    So, in nowadays of huge variety of sensor form-factors and formats its better to do a brief test, or to check online before making a decision on which wide youll use.
    Laowa has some extremely cheap and relatively good wide lenses, that cover up to FF though.
    Senior Member jake blackstone's Avatar
    Nov 2007
    Grading slight vignetting out of the picture by using an inverted vignette is incredibly easy. It's not a perfect solution, but under the circumstances, it's an easy fix.
    To make the process even easier, just shoot an evenly lit card and then use that image to create a perfectly inverted vignette.
    Jake Blackstone
    Colorist
    MOD Color Web Site
    Demo Reel
    San Diego, CA
    In REDs defense, even the well established lens makers weren't thinking beyond S35 for motion work when the RPPs landed. RED has been ahead of the curve in many ways, but even the Madman doesn't have a crystal ball. I would add that the RPPs were an attempt to put cinema glass in the hands of owner/operators and smaller rental houses who couldn't ROI Cookes/Zeiss/Leica/Angie/etc. In retrospect, I still think the price/performance proposition was solid at the time of release. These days, I consider the Sigma CINE line the best value in cinema optics. YMMV.
    Cheers - #19
