Hey guys
I have had a Bolt 500 DSMC2 module for a little over a year now and I have noticed that the wireless output from DSMC2 bodies (both Helium and Gemini) is not a clean signal. When comparing the image with a clean SDI or HDMI signal from the base expander the image from the Bolt module has higher contrast (what seems to be a gamma transform on top of the normal IPP2 color).
All monitor outputs are set to Rec709 SDR and they all have the same image pipeline without any LUTs. I’ve also confirmed that the Bolt XT Rx isn’t applying a LUT downstream. I’m running the latest alpha build FW 7.3 on the Helium and the Bolt has the latest Fw from Teradek. I’ve confirmed that the look is actually crushing the blacks with scopes on both my Flanders and Cine7 to ensure the gamma transform is in the signal.
Has anyone else seen a similar issue with this module?
Kenny
