Click here to go to the first RED TEAM post in this thread.   Thread: "mirrorless" with optical viewfinder
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. #21
    Senior Member Charles Angus's Avatar
    Jun 2007
    Toronto
    Quote Originally Posted by fde101 View Post
    Is it possible to make a transparent image sensor and put the mirror behind the sensor, instead of in front?
    No. In addition to the previously mentioned reason, the image would be out of focus.
    edited to remove redundancy.
    Jun 2007
    Toronto
    All ideas which involve something being between the sensor and the lens are impossible.
    A flat piece of glass changes the optical path - Bolex came up against this on their reflex cameras. You need a specially designed lens (they call them RX lenses) to compensate.
    The only advantage I see of an optical finder is that you can always see your frame, even if the system is off. I still double-take on EVF's when the AC has helpfully shut down the camera during some downtime.
    It sounds stupid, but it is very nice to always be able to see.
    IMHO - nonsense to all this optical finder twaddle - worry about the what's in front of the camera.
    Banned
    Sep 2008
    Quote Originally Posted by AngusChandler View Post
    Isn't that the job of the lens -- to focus the image?
    Why would a transparent sensor have any more of a focusing problem than an opaque one?
    Just because the tech may not exist yet doesn't mean it's impossible...
    Quote Originally Posted by Jannard View Post
    We haven't had one request for an optical finder in the last year and a half.
    Jim
    The only problem is :
    RED EVF Price: $2,950.00
    Nikon D700 Body : $2,999.99
    I hope you can do everything else for $49.99 :holloween:
    Alan Fletcher (aka alanf): Hemi-semi-demi-pro Newspaper, Location and Event photographer -- Mainly Olympus (E1,E420) and KM (3xA2) gear.
    Senior Member Pietro Impagliazzo's Avatar
    Mar 2008
    Rio de Janeiro, BR
    Why do you want a mirror? I forgot. Oh, I remember now... so you can't see in low light.
    I remember going to CML early in the RED ONE development. The only advice I was given was that if we did not have an optical viewfinder, we wouldn't sell any cameras and wouldn't really have a professional camera. We haven't had one request for an optical finder in the last year and a half.
    Jim
    Way to go Mr.
    Just shut up those nostalgic pricks with some new kick ass EVF.
    :red_bandana:
    Acintyah khalu ye bhava na tams tarkena yojayet
    There's no use arguing over that which is inconceivable
    Pietro Impagliazzo
    vimeo.com/impa
    impagliazzo.500px.com
    Oct 2008
    Jim
    EVFs seem to work acceptably for video. I haven't found that to be the case with stills.
    An SLR TTL viewfinder produces a visual resolution of approximately 1800x1200, has zero latency, uses no power, and costs ~$100.
    While an electronic system can't ever reach those specs, it may not have to. I would suggest that a practical EVF for stills would be acceptable with a resolution of 1280x848, a maximum latency of 20ms in EV0 (very dark) conditions, a maximum latency of <5ms in >EV8 conditions, a power usage of ~2W (including sensor and processing) to not impact battery usage too severely, and a cost of ~$500.
    As far as I can tell, your current system needs a roughly 5x improvement in latency, 10x improvement in power consumption, and 5x improvement in cost to meet those specs.
    As for low-light performance, I can tell you that I can see better with my SLR through an f15 optical train than I can with my EVF through an f4 optical train. This is mostly a function of the sensor and larger sensors can close that gap, but the reason EVFs have the odd reputation of working better in low-light is because they can increase their integration times. The Mallincam is famous for this in the astro community, but it uses integration times of up to 56 seconds. Obviously, this approach is not acceptable for stills, and I don't believe EVFs have any current advantage when low-latency is maintained as mentioned above, which will be required by still shooters used to using OVFs in dark conditions.
    Finally, there's the issue of autofocus. A mirror enables phase-detection autofocus, which in my experience is at least two orders of magnitude faster, more sensitive to small subjects, and better at tracking than even the best contrast-detection autofocus. This may be the largest barrier to a mirrorless still camera intended to compete with SLRs, unless CD AF can be improved by a couple of orders of magnitude or a way can be found to do TTL PD AF without a mirror.
    Hope that helps, and I wish you the best in your development efforts. I'll be interested to see what you come up with and what practical benefits it might bring to those of us that shoot stills in difficult conditions.
    Banned
    Sep 2008
    Quote Originally Posted by Impagliazzo View Post
    Just shut up those nostalgic pricks with some new *** EVF.
    Yeah, I'll likely stick with my Canon DSLRs either way, so don't go by me...
    Banned
    Sep 2008
    BTW, I'm curious... how many of your company's primarily-for-professional-still-image-capture cameras have you sold in the last year and a half?
    There's a BIG difference between pro still work and pro movie work. Even if the camera handles both very well, that doesn't mean its users will...
    There is a LOT of potential in what you are doing here, and I wish you well... it is likely to be a long time before I personally consider replacing my Canons for stills, but if/when I do, I seriously doubt I'll even think about anything without an optical viewfinder.
    Again, that's me... others will vary of course!
  10.   Click here to go to the next RED TEAM post in this thread.
  #30
    Red Leader Jannard's Avatar
    Having shot stills for over 30 years (Hasselblad, Nikon, Canon, Olympus, Linhof, Mamiya, Pentax, Fuji... and a whole bunch more) I agree that shooting stills is somewhat different than shooting motion. But having heard that there was no substitute for an optical finder in motion less than 2 years ago... I hope you will be open minded that the possibility exists that there just might be another solution here as well.
    As for how many "primarily-for-professional-still-image-capture cameras" we have sold in the last year and change... just as many as we did motion cameras two years ago...
    Jim
    "The camera is arguably one of the most important of all inventions… it is the single tool that has the ability to stop time, record history, generate art, tell stories, and communicate messages that transcend language like nothing else ever conceived."
    "Everything in life changes... including our camera specs and delivery dates..."
    We reserve the right to refuse service to anyone with a bad attitude.
