Thread: Spec sheet for Komodo? Where are the listed TC I/O & Audio inputs for Komodo?
Results 1 to 9 of 9
  1. #1 Spec sheet for Komodo? Where are the listed TC I/O & Audio inputs for Komodo?
    Oct 2014
    Auckland, New Zealand
    Am a Sound Mixer who is going to be working with a Komodo soon on a short film, would be handy to know exactly what input connectors and capabilities Komodo has for audio and timecode? Can't seem to see it listed anywhere on RED.com
    http://IronFilm.co.nz/Sound/ (Sound Recordist based in Auckland, NZ. Happy to travel too)
    https://www.youtube.com/c/SoundSpeeding
    Mar 2011
    Toronto, ON Canada
    Komodo has this 9 pin EXT interface.
    http://www.reduser.net/forum/showthr...or-Pin-Diagram
    Wooden camera has this nifty breakout box to get a standard 5pin timecode inout.
    https://woodencamera.com/products/b-box-red-komodo
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Aug 2011
    Oct 2014
    Thanks rand! I couldn't find that when I went to https://www.red.com/downloads
    Reading this I see it has both an internal mic, and can take stereo 3.5mm
    Any chance I can record both an internal mic and an external input? Like you would with a Sony FS7.
    (no problem if you're still limited to 2 tracks, and can't do 4 tracks although that would be preferable)
    Can I set playback so it ONLY plays back the left or right channel?
    Aug 2011
    David,
    You're Welcome! I'll see if I can find that out, if someone who has the Komodo doesn't answer this first.
    Aug 2011
    David,
    Not sure if this video answers either of your questions but try this video out at the times listed below
    37:32 — AUDIO & TIME CODE SETTINGS
    37:48 —— Internal Mic & Audio Settings
    38:42 —— External Mic & Audio Settings
    39:56 —— Time Code Source (Internal / External) & TC Jam
    Quote Originally Posted by David Peterson View Post
    Unlike DSMC2 at least at the moment Komodo only records audio via the 3.5mm or the scratch mics, so stereo audio at any given time.
    Haven't seen any mutable tracks during playback on a RED camera to date, though I'm sure people can add it as a feature request.
    As mentioned, the EXT port is the place for TC, Sync, etc. There are cables and break out boxes.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member andrewhake's Avatar
    Oct 2009
    https://thomsonvisualsstore.com
    These guys have put together some great TC to EXT cables for Komodo that work great. Pretty much have something for all the popular TC boxes out there. Much better solution that trying to adapt to standard BNC connection if your box doesn't already have that. They test them on their own Komodo before shipping them. All the cabled I have gotten from them have worked great. Very similar to any other red camera with a TC box attached.
    And as others have mentioned currently you can't record both internal mics and 3.5mm simultaneously. I hope that will be added as having the internal mics recording as backup for extremely loud car stuff as actually saved me in the past.
    DSMC2 Gemini
    Komodo ST
    Senior Member Christoffer Glans's Avatar
    Jun 2007
    Stockholm, Sweden
    or the scratch mics
    How good are these? Not interested in their audio quality but how sensitive they are. If they are enough to get a good waveform sync to dedicated audio files I don't need timecode for sound or a proper clapper.
    "Using any digital cinema camera today is like sending your 35mm rolls to a standard lab. -Using a Red is like owning a dark room."
    Red Weapon 6K #00600 Red Komodo #002397
