Thread: Komodo REDCODE RAW and Media F.A.Q.
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1 Komodo REDCODE RAW and Media F.A.Q.
    Hello all!
    With Production Black bodies getting out into the wild I thought I'd wrangle up some of the many questions I've been getting since May regarding recording media.
    CFast 2.0 Media Briefing
    RED Komodo utilizes off the shelf 3rd party CFast 2.0 cards. Nice as they are readily available around the world. However, not all CFast cards are created equal and you do want in general to use RED approved media that have gone through the testing they have done. I'll be sharing that info as well as some of my own experiences here.
    What CFast 2.0 Media is RED Approved
    So far what RED has approved is:
    - Angelbird 256GB, 512GB, and 1TB (*RED's branded media is indeed Angelbird and is what I'm personally using as seen above)
    - ProGrade 128GB, 256GB, 512GB, and 1TB
    - Sandisk Extreme Pro 128GB, 256GB, and 512GB
    - Sony 128GB High Performance G Series
    * I'm betting more cards will be added officially once they are tested.
    What happens if I use unapproved CFast 2.0 Media
    Whelp, first you'll get an error message saying the media is not approved. Not necessarily a bad thing and you likely will still be able to record if the card has the performance to do so.
    However, the DANGER of using slower CFast 2.0 Media is dropped frames or even a lack of ability to record in certain compression ratios.
    Your livelihood and footage being on the line, I'd strongly recommend investing in good media.
    Can I use a CFast Cable Adapter to record to SSD
    Yes! This is possible. You'll get the unapproved media message, but it does and can work. Do 100% test this thoroughly before deploying on a project to ensure it's working as expected.
    *side note - The Media Bay Door on Komodo is actually removable which is ideal for exactly this setup. Make sure those cables are securely plugged in if you are doing this. When in doubt, gaffer's tape is your best friend or some sort of cable clamp system.
    REDCODE RAW and Data Rates?!
    Komodo records compressed RAW in the form of REDCODE RAW or ProRes 422 HQ in 2K or 4K resolutions. If rolling in ProRes 422 HQ the camera scales down the footage appropriately, i.e. 6K->4K.
    REDCODE RAW is currently available in three compression ratios: HQ, MQ, LQ. Those have an impact on your maximum recording time as well as image quality.
    Generally my recommendations for selecting REDCODE RAW is:
    - HQ = Cinema Grade, High End TV/Streaming, VFX, Detailed Scenes, Still Extraction
    - MQ = Cinema Grade and High End TV/Streaming
    - LQ = General Television, Online Delivery, Documentary, Interviews, Long Takes
    * I personally roll HQ or MQ most of the time, but I'm also mainly creating work that fits in those categories above.
    Here's an example of approximate record data rates for a 24fps project with 512GB cards in 6K 17:9:
    - REDCODE RAW HQ = 30 minutes
    - REDCODE RAW MQ = 45 minutes
    - REDCODE RAW LQ = 75 minutes
    Double this for 1TB, half this for 256GB. Generally I'd recommend 256GB cards and up. I use 1TB cards at the moment.
    For a similar concept, if you are rolling with ProRes 422 HQ in 4K about 90 minutes of roll time.
    Hopefully that's enough info to get you up and rolling.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Tim Daust's Avatar
    May 2016
    Atlanta, GA
    thanks for doing this Phil !
    Tim Daust
    Reelmind Studios
    WEAPON HELIUM 8K S35 #6197 "Wicked"
    DSMC2 GEMINI 5K S35 #15175 "Jade"
    KOMODO 6K #0011 "Tangie"
    @TimDaust @ReelmindStudios
    Senior Member yann LHENORET's Avatar
    May 2013
    Thanks very much for the summary Phil.
    Documentary shaper, "that guy...".
    https://m.imdb.com/name/nm1523882/?ref_=nv_sr_srsg_0
    Senior Member vincent kardasik's Avatar
    Apr 2009
    Capbreton, France
    Thanks for this Phil.
    Reading your post made me realize that I probably need more storage than I first thought.
    DSMC2 Monstro & Helium packages ready to shoot
    Gates Pro Action DSMC2 Water Housing
    SPL DSMC2 Custom Water Housing
    vincentkardasik.com
    Hossegor, France
    Water Cinematography Reel
    Instagram, Twitter and Vimeo
    Quote Originally Posted by vincent kardasik View Post
    I think everybody is different and I know for me every project is different. I finish a day with sometimes 30 minutes of material and other times 12 hours of material. Truly depends on what we're filming.
    Generally though I like 1TB because my small reptile brain can handle 1 hour or 1.5 hours per TB. Somewhat what I have been used to with my Monstros, though I'm rolling mostly with 2TB mags these days.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Kemalettin Sert's Avatar
    May 2009
    Los Angeles CA
    Which cards works with Alexa Mini and Komodo at the same time?
    Quote Originally Posted by Kemalettin Sert View Post
    At the same exact time, well you will need two cards :)
    Kidding.
    Angelbird is officially RED and Arri approved which is one of the bazillion reasons I went with their cards. I haven't tested a lot of these on Arri, but if they work for Komodo they should work on the Mini.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Scott Balkum's Avatar
    Jan 2015
    Austin, TX
    Love it! Thanks for sharing
    Red Dragon-x "Big-Skippy"
    www.imaginationx.com
    May 2009
    Los Angeles CA
    Kidding.
    I thought only Angelbird ARRI CERTIFIED ones works on Alexa Mini?
    A couple questions to clarify (as I wait impatiently for my Komodo to come in):
    What are the record times for HQ, MQ and LQ on 2.4:1 on 512gb?
    Should there be any difficulty using Angelbird Paired CFast Media for the Z-Cam or BM Ursa Mini? (They have the better deals ... But from what I can tell there is no real difference other than paired.)
    Scarlet-X #2034 "Bea"
