I just shot a test with magnetic ballast HMI's and was very surprised- we went to a time base of 24fps, shot 24, 60 & 120 fps, & had to adjust shutter 'angles' for each, and were unable to capture flicker-free at 120 fps at any shutter angle- very bizarre.
Also point to note that "relative mode" in the shutter menu seems to imply "manual" , where the shutter angle may be controlled independent of the frame rate, although the term is a little awkward.This helped in as much as shooting 60 fps worked at a 45 degree shutter as well as a 90.
Whatever the case, in controlled enviornments, I would avoid magnetic ballasts altogether, use only electronic and any location with industrial lighting, including fluoros, I would test before the shoot date, before promising any frame rate and shutter angle options.
