Thread: Support for Red Rocket X for 2019 Mac Pro Catalina/ Big Sur
Results 1 to 6 of 6
  1. #1 Support for Red Rocket X for 2019 Mac Pro Catalina/ Big Sur
    Sep 2011
    I recently got the 2019 Mac Pro 16 Core with 2x AMD Pro Vega II Duo 96Gb RAM and would love to be able to use my Red Rocket X on Catalina/ Big Sur. I still use it with my 2013 Mac Pro running Mojave. Are there any planned updates to the firmware? It will help in transcoding 8K Monstro/ DXL FF footage. I am unable to install the firmware in its current iteration. Thank you for your help.
    Local 600 DIT
    Nov 2013
    U.S. of A.
    I’m not sure how big a difference the Rocket X will make on that system. What kind of frame rates are you seeing without it?
    DP/Colorist
    www.joelvoelker.com
    Seattle, WA
  3. #3 15fps
    Sep 2011
    15fps in Metal on my 2019 Mac Pro in half res good
    30fps in Metal on my 2013 Mac Pro with RRX
    I am troubleshooting it with Blackmagic. Blackmagic forum members are recommending dialing down the debayer to quarter res good. I don't need 2019 system if I have to do quarter res debayer. I have 16x lanes on 2019 Mac Pro that can truly leverage RRX. So far it has lived in a Sonnet Chasis over thunderbolt 2 and never really lived up to its potential.
    Local 600 DIT
  4. #4 Resolved(Pun intended)
    Sep 2011
    After changing the preference in decode from debayer to decompression and debayer, the frame rates improved. Metal decompression was implemented in Resolve in 16.2.1
    8K FF Ana to DNxHD (Half res Good) went from 15fps to 78fps
    8k FF to DNxHD(Half Res Good) went from 32fps to 88fps
    GPU usage has shot up to 15X and CPU usage has gone down 4X. I would still hope that Red would upgrade the firmware to work with Big Sur for RRX since it allows Full Res debayer.
    Local 600 DIT
    Hello, I have an iMac 2020, and while I may have 2 Egpus connected via Thunderbolt, I am really in need of installing my Red Rocket. It would really help! Has anyone found a way to install the drivers on Big Sur?
    Junior Member
    Oct 2010
    These instructions have worked on Catalina, not sure about Big Sur. Most instructions are in Terminal.
    DIRECTIONS:
    # You need to have the RRX kext driver to do this. It's in the installer file and can be extracted (Suspicious Package) or taken from a previous supported system.
    # Big OS updates will likely kill this driver and it will need to be reinstalled. It will NOT run under M1 because it was compiled for Intel.
    # DISABLE SYSTEM INTEGRATION PROTECTION
    sudo spctl --master-disable
    # CHECK IF DISABLED
    sudo spctl --status
    # ?? MOUNT BOOT VOLUME AS R/W (DOES THIS DO ANYTHING?)
    sudo mount -uw
    # COPY KEXT INTO PLACE
    sudo cp -R /path/to/redrocketx.kext /Library/Extensions
    # REPAIR PERMISSIONS (-rwxr-xr-x) FOR EXTENSIONS RECURSIVE
    sudo chmod -v -R 755 /Library/Extensions
    # REPAIR PERMISSIONS (ROOT) FOR EXTENSION DIR
    sudo chown -v -R root:wheel /Library/Extensions
    # TOUCH EXTENSIONS DIR
    sudo touch /Library/Extensions
    # UPDATE KEXT CACHE
    sudo kextcache -i /
    # REENABLE SYSTEM INTEGRATION PROTECTION
    sudo spctl --master-enable
    # REBOOT MACHINE
    sudo shutdown -r now
Tags for this Thread
View Tag Cloud
