Click here to go to the first RED TEAM post in this thread.   Thread: What is this accessory ?
Results 1 to 10 of 10
  1. #1 What is this accessory ?
    Banned
    Jan 2007
    wanted to ask those forum members who went to NAB.
    what is this grip-shaped thing in the lower center of the attached image ?
    ( itīs touching the "G" in "Gizmondo" )
    I think it's the super grip without the attached grip on the bottom, same as the one on the left
  3.   This is the last RED TEAM post in this thread.   #3 What is it ?
    Red Team Stuart English's Avatar
    Irvine, Ca
    Yes, its the SuperGrip without a lower grip handle attached.
    Workflow Wizard
    Banned
    Jan 2007
    Thanks !
    that is the item just above the 'M' in the photo?
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    The item above the "M" in "GIZMODO" in the PL cap is the B4 to PL converter for using B4 lenses with the PL mount on the RED ONE. They optically enlarge the image ~1.32x, allowing for 1080p or maybe 2K coverage, depending on the optical coverage of your lens. For example, while the lens may cover the full 2K area with the converter, there may be nasty fringing and aberration. It all depends on your glass.
    Quote Originally Posted by Brook Willard View Post
    so is that different to the B4 mount that sells for $3500 or is that it?
    edit: meaning, i though that the B4 mount would be interchangeable like the Nikon, Canon and PL mounts, so this would just be a converter, not a mount? have i got the wrong end of the stick here?
    Senior Member Michael Ragen's Avatar
    NYC
    Ah, now i get it. I thought the grip handle was just part of the Supergrip. I didn't know it could be removed.
    Burbank, CA
    Mike, it can be removed... at least in the prototype I saw. I don't want to comment on the final design because I'm not involved and it's really not my place to comment.
    Chas, that is the $3,500 mount/adapter. You can mount it on a lens, you can mount it in the PL-mount, you can keep it separate. It's up to you. It's a very easy piece to swap around.
    Banned
    The supergrip handle can be removed but not the top clevis portion. I think RED wanted it such that you can put custom grips on there if you are so inclined.
