I've also encountered this phenomenon, but only on later model cameras. I'm pretty sure this problem doesn't exist on our camera (#247). I wonder if anyone with the new mounts have this problem too?
Same problem here but you can do it without it moving. All the time watch a monitor closely in case it does shift. Turn the screws very slowly little by little, constantly changing back and forth between the two. Even when it starts to get a little tight keep on going only very small turns bit by bit and still changin back and forth between the two.
Works well for me and if i try and do it any other way it just slips.:pinch:
Not having the opportunity to adjust backfocus yet, I might be out of turn with this idea but it occurred to me that after you have adjusted your backfocus and before tightening the screws, couldn't you apply a piece of tape to hold things in position while you tighten it up? Another idea would be to also apply two pieces of tape with a line marked between them spanning the gap, like Doug did to give you a visual reference to see if it had moved at all. Just a thought.
Mark,
The problem is not that the ring is moving, it's not - it's just the tightening of the screws that causes it.
Jack
I do.
The way it's being done by using threaded pieces is a problem area no matter what the pitch is. There are however other ways of doing it, but they get complex and therefore pricy. Linear travel that is basically slop free and maintains parallelism requires complex mechanisims like the moving parts of a real zoom lens.
