Click here to go to the first RED TEAM post in this thread.   Thread: Major Announcement...
Closed Thread
Page 12 of 14 FirstFirst ... 2891011121314 LastLast
Results 111 to 120 of 135
  1. #111
    Quote Originally Posted by rgdfilmsRED View Post
    No controversy. Thank you Red team once again for being so loyal to us all.
    Agreed. If I've read everything correctly, there's not a single utterence of controversy in this thread. We're all happy to get a better camera. Even the delay isn't controversial. It's completely fine. I just wish I knew exactly what the delay is, so I can start book my cast and crew with some certainty. But Jim said we'll know in two weeks, so I can wait. It's not as though we really have to be patient with Red, because everything moves so fast, so all's well.
    Christopher Kenworthy
    www.christopherkenworthy.com
  2. #112
    Senior Member Stephen Gentle's Avatar
    Jan 2007
    Brisbane, Australia
    Great news guys! How much more dynamic range will there be? One or two more stops would be really cool (what's the limit for 12bit though?)
    Quote Originally Posted by Roxco View Post
    Looks like another door opens for software to add grain in post.
    Why can't you just make a Tyco Camera for the masses? ;)
    BTW: Thanks for the update,
    Rosco
    P.S. Check out the Toyco raster and s/n ratio below
    - http://www.reality.demon.co.uk/tyco.htm
    - http://www.bitpress.com/tyco/fren.html
    Hey cool! That was my first camera (I was like 10).
  3. #113
    Senior Member Rick Darge's Avatar
    Quote Originally Posted by Jannard View Post
    minor delay...
    Keep in mind, he said minor not major. A major delay would be 6-18 months. Minor to me, smells of 1-3 months max. These are good peeps. :construction: What a sweet business to be in right now!
    ANGENIEUX LENSES • CANON k35 SUPERSPEEDS PL
    O'CONNOR • ARRI • DEDOLIGHT • KINOFLO • LTO5
    www.theredshooter.com
    rgdfilms@gmail.com 310-435-3134
    WWW.ZENDOGMOVIE.COM
  4. #114
    A 12 bit linear system can record 12 stops at most, so take that as the upper limit. (I believe that a non-linear response or more than 12 bits would mean a complete system redesign, which I didn't hear being suggested. I suspect they just found one or more parts with improved specs to plug into the existing design.) If you look at the curve that the 11.3 stop claim was based on, you will observe in the bottom left region, the lowest 1 or 2 stops of exposure have a much different slope (flatter) than the rest of the plot. This suggests it is an area of significantly increased noise. If the improved circuit has lower noise, this will give you a much more usable image in the underexposed areas, without necessarily increasing the measured dynamic range number at all. In the end, you care about what the picture looks like and the DNR number alone doesn't tell us that.
  5. #115
    Ok maybe I'm being thick headed but my understanding was that the 12bits was just the ceiling at which you see no more improvement from 12 stops. In other words 12stops @ 14 bits is just wasting two bits to noise. That still doesn't mean you can only record a maximum of 12 stops to 12 bits correct?
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
  6. #116
    I really hope we are talking about weeks here, not months...
  7. #117
    Senior Member Poi Boy's Avatar
    I'm hoping two weeks max !
    -A
    Alex Viarnes
    Poi Boy Productions
  8. #118
    Moderator Häakon's Avatar
    Los Angeles, CA
    Me too. I've got a lot of projects with RED-hungry clients this summer!
  9. #119
    chromatic adaptation.....
    For those who want to know (and the fresHDV guys can attest to have been in a conversation with Graeme about this)....
    Changing your white point affects your perception of color. You can see this in CRT displays. Moving the display's white point from D65 to 9300K makes reds appear less saturated. To compensate for this, a lot of consumer CRTs will oversaturate the reds and mess with the hue.
    When you white balance an image, you kind of have the flip side to this. You white balance from whatever the scene is (for outdoors scenes, this changes throughout the day and depends on cloud cover) to your target white point. Target white point for video is D65, for DCI is P3 (I think; see etconsult.com), and for film is 5400K.
    *White point = the color of white. Sort of like the color temperature of a light.
    Ok, so when you change the white point you can numerically change all your values so that they look the same. There are different numerical schemes for this, such as the Bradford transformation. Bruce Lindbloom's site goes into some of the color science of it:
    http://brucelindbloom.com/Eqn_ChromAdapt.html
    (and see the links to other pages too)
    2- One of the problems with color science is that we don't understand everything... i.e. a lot of the color perception models are imperfect. I've heard a lot of good things about Fairchild's book Color Appearance Models 2nd Ed and it's probably a good reference for color science stuff.
    I think that's the Coles notes version. You will be tested on this. ;)
  10. #120
    Banned
    Jan 2007
    "If we deliver on time, but the product has defects, we have not delivered on time."
    - Philip Crosby Let's Talk Quality, 1989
    Please take the necessary time to make this a camera for the history books. I've got my reservation locked. I'm not going anywhere. Appreciate all the hard work.
