It was for in business not resale use.
As long as it is not for resale they will not stop it at the border.
I can imagine that selling the electrical devices without CE mark on it will get you in to the trouble.
The way around it, is to build your equipment powered by 24V or less an then to use CE approved little black box to plug it to the wall outlet on one side and to the camera or camera charger on the other side. We were doing it with multi channel audio mixers. We took power supply out of the mixer and use low voltage only on it. Then we bought CE approved in line voltage converter/power supply to power the whole audio mixer from it.
Two separate devices, one low voltage second locally approved.
http://www.cetest.nl/european_new_ap...directives.htm
Approval process is not a big problem ether if handled by the local consulting company.
They have experience how to do it fast and without the pain.
