Hi,
The DNxHD Qts that I cut from seem a little noisy, so I wanted to reconform from the R3D files to an uncompressed QT and reconform that into Avid.
I almost had it but I had a couple of questions. In the results folder I had some QT's that had multiple versions, so I am not sure which to select when I batch import back into Avid.
Also most is shot 16:9 4K which is fine, and Some is 2K 100fps which some has been retimed in avid and some not. The retimed looks fine, but the normal 100fps is coming in very strangely! Any clues?
Max
