Hello everyone,
Does anyone use this mic with red one new audio board?
Is it ok? any problems?
I tested it with sony pd170 and panasonic 100A, it was fine, but not working with red. Any suggestions?
Thanks.
Hello everyone,
Thanks.
Working just fine here...
The NTG-3 would be a very good choice for use with RED, or any other camera needing a good shotgun mic at a good price. You will want the upgraded audio board in your RED to make proper use of this mic over phantom power, otherwise you will need a separate battery power adapter or other external power source.
It's best to go through a mixer first if possible. I had a chance to test the RODE NTG-3 outdoor and indoor in this example http://vimeo.com/1977907
The feed was direct into a Panasonic HPX500. No mixer. After getting a Sound Devices 302 field mixer and hearing the difference, I'd say that is the best way to go.
-Guy
Thank you guys,
very helpful.
This may be true practically, but I'll hand you the possible reason.
First, the pre-amp on your mixer likely has increased headroom, lower noise, and probably a larger dynamic range than the stock RED (I am unsure however of the precise specifications of either).
Second, depending on the cord-length used, and the mini-XLR adapter, the signal will degrade before it gets to the pre-amp, or there could be attenuation or an impedance problem.
Third, the mixer might offer cleaner Phantom than the camera, for a number of reasons (battery, voltage regulation circuitry).
And if I think of anything else I'll let you know.
I have gone direct into Panasonic pre-amps before, and they really aren't that good. Panasonic doesn't have much Pro-Audio experience like Sony, and even Sony's products are mid to mid-high quality (especially on their video products).
Sending a line signal into the camera probably alleviated the problem of Panasonic's pre-amp, which is why it sounded better. That being said, with the new audio board, the difference between the line-fed and RED should be smaller, however I'd wager that running the signal through a $1,300 mixer will still yield a slightly better signal.
Having not had the opportunity to use the new RED board, I'll take your word for it and await the day I do. On that note...
Do you have a RED One with the new audio board? If so we should arrange a sampling (ack, can't breath, bad, terrible pun, falls on floor).
While RED is trying not to give away all of their secrets, I often wish that specifications for parts like the audioboard were available. And I mean of course in greater detail then 48V phantom, 48khz ADCs, and (8? or 12? db headroom, no quotes on these numbers) which doesn't actually tell me that much.
